MUSTANG SN95 TURBO
why do you think the crank sensor would not work? You take the crank pulley off and then put that wheel on behind the pulley and then mount the pick up/sensor with the bracket. Then like I said above you will need to space the remaining pulleys out 3/16" if I remember correctly to get the belt to line up.
robskw
robskw
Sao Paulo
Sure! now i understand! bought The explorer can waiting it comes!.
Guys just another question i dont have the AC! only steering pump and Alternator. Is there any kit avaible to relocate the alternator?
Thanks
robskw
robskw
Sao Paulo
guys found this kit https://www.ebay.com/itm/BILLET-ALUMINUM-1979-93-FORD-MUSTANG-5-0-ALTERNATOR-BRACKET-SET-POLISHED/362199947471?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49893%26meid%3De371a9baf4714c2a8078959b59fd2958%26pid%3D100005%26rk%3D2%26rkt%3D2%26sd%3D263411691544&_trksid=p2047675.c100005.m1851
they are for 93 Mustangs! do they fit in the 95?
the water pump is clowise or counter clockwise on 95 GTs?
i think this is a good solution for me just need to make sure if it fits
Staff member
Lawrenceburg Kentucky
I can send you this exact bracket for $35. Ill include bolts too.
robskw
robskw
Sao Paulo
ahh no bro i mean for the 2v, this one wont fit to me with the turbo!. i am just trying to move my alt because my belt is making noise with the modifications i did, trying to find a alternator relocation kit that would fit the 5.0 2v
evilcw311
Most Evil Member!
Louisville, KY
5.0 isn’t a 2v. 5.0 is a pushrod motor. 2v/3v/4v are all 4.6 mod motors.
robskw
robskw
Sao Paulo
ops ya bro i mean my pushrod engine.
so theres no alternator bracket that would fit to me?
those from 83 mustang could fit with some mods?
evilcw311
Most Evil Member!
Louisville, KY
Not 100% sure it would work. You’d possibly have to change the water pump, timing cover, accessories, and radiator to the 87-93 style. Seems like a lot to make it fit. If you don’t have a smog pump anymore I’d be curious to see if it could be moved to it’s spot.
robskw
robskw
Sao Paulo
robskw
robskw
Sao Paulo
guys one question, anyone here already installed a ON3 turbo kit?
Planning to change my ebay turbo manifold for a ON3 kit hotside and coldside maybe..
because changing headers i dont have to move my alternator i can just use it like OEM..
they are good kits? any problems with them?
evilcw311
Most Evil Member!
Louisville, KY
Some had issues with the earlier kits not lining up right. Biggest problem is the v-bands they send are garbage so be prepared to buy separate v-bands.
Check out B&G turbo. Much better fitting kits. Only downside is there’s usually a bit of a wait
robskw
robskw
Sao Paulo
ya bro tried contact B&G Turbo but them never answer me by email, Looks like they are out of business
96GTPlanB
