wldtang
I don't know of another conversion such as this. Many similar but not exactly like this.
My 94 cobra has went through many changes over the past couple of years. I have finally settled on one setup. At least for now.
This is a major conversion.
The car is getting everything swapped over to 03 stuff.
Motor
trans
complete wiring harness
dash shell
brake system
pedals
steering column
fuel system
a/c system
coolant system
Mods will be:
Steggy stage 5 Ported eaton
Accufab plenum port to steggy
2.76 upper / 2lb lower pulley
60 lb inj
SCT 2800 maf
longtubes
x pipe
catback
JLT CAI
Accufab TB and plenum
4 piece idlers
egr delete
SCT Xcal II tuner
Spec stage 3+ clutch
Fore top hat
GT pumps
dual FPDM's
First I started stripping the car down. Everything needed to come out.
I installed a PA Racing tubular K. Next I will be installing 03 A arms, sway bar, steering rack. I will re-use my spindles and brakes.
I then stripped the interior.
Pulled the dash and converted it. I wanted to keep most of the 94 look. Mostly because of the color. True black. Not charcoal like the 03-04's.
I swapped my dash pad and heating ducts over to the 03 metal frame and installed all of the 03 wiring.. Installed the 03 cluster.
03 pad after removed from the shell
03 dash shell with pad removed
94 dash before it is stripped
94 stripped shell and harness. Pad was relocated to new 03 dash frame
94 dash converted to 03 internals converted
I had to change the pass side air bag connector.
From Brown
to Black
Updated: 12-28-07
Removed the abs module and front brake lines.
Removed remaining harness in engine bay
Test fitted the hydroboost. I need to drill one alignment hole.
Removed 94 horn and installed 03 horn
12-30-07
Trimmed the brake hole opening for the hydro boost and drilled the alignment hole. It now fits.
Installed the 03 pedal assy.
Hope to move the lower rad. mounts this week.
1-6-08
Finished bolting up the PA Racing K member and installed the 03 cobra front sway bar. I will complete the front suspension once I install the steeda X2 balljoints on the 03 A arms.
Installed the dash assy and pedal assy. Wire connectors all mated up.
Broke my *&#@ windshield trying to tight the top three dash bolts. Ratch slipped and hit the windshield and crack. Guess I get to buy another one.
Need to get my suspension completed so I can move the car for engine bay paint. Once that is complete, assy should move faster.
Got my stage 5 steggy ported eaton back today.
Stage 5 port
front drive rebuild
2.76 pulley install
accufab plenum port to my eaton
What a beaute.
Fore top Hat - just need some GT pumps now.
Finished my front suspension.
Bolted up the K member
Installed Steeda X2 balljoints in the 03 cobra control arms
Install 03 struts. Retained my 94 cobra spindles,, brake caliper, abs sensors, and soft brake lines.
Also switched the 03 cobra front sway bar.
I am using the 03 cobra front rotors. Just need to get them shaved to clean up.
I also need to order a MM service 6 kit so I can put a boot over the strut rod.
1/19/2008
Ordered a Fore hat about a month ago from Lethal.
Ordered a new sending unit and dual GT pumps from Tousley Ford.
Today I decided to assy the hat.
All went very well. The only problem I had was when taking the stock filter off of the new GT pump, I broke the small tab that helps hold on the sock.
The fore supplied sock seems to fit very tight on the pump so I should be ok.
Update 3-16-08
Finished patching the pass side fender apron (from the power pipe when I had the S trim on the 302). Rolled the car outside and scrubbed the engine bay with Simple Green. Wow does that stuff work. Changed out the wiper motor and linkage assy.
The 94 wiper motor uses a different connector than the 01+ motor. I just change the whole assy since I had it.
I also adjusted the hood hinges so the 96-98 cobra hood lines up.
Next up, engine bay painting.
Motor
trans
dash shell
brake system
pedals
steering column
fuel system
a/c system
coolant system
Mods will be:
60 lb inj
SCT 2800 maf
longtubes
x pipe
catback
JLT CAI
4 piece idlers
egr delete
SCT Xcal II tuner
Fore top hat
GT pumps
dual FPDM's
From Brown
to Black
Updated: 12-28-07
12-30-07
1-6-08
Stage 5 port
front drive rebuild
2.76 pulley install
What a beaute.
1/19/2008
Update 3-16-08
