my first two mods
Cox98Gt
Ga
well guys i did my first two mods to my car the past two weeks. i put a aftermarket radio in my car, and i wired my fog light to be able to be turned on without the headlights. i am very happy with both upgrades.
C
Cox98Gt
Ga
thanks guys i cant afford expensive stuff to mod with. so cheap easy ones are first on the list
Gallows
Summerside, PE, Canada
Watch the classifieds for deals on used parts. Sometimes you can get near new parts for bargain bin prices.
DESERTCOX05 said:
I have infected him with the mod bug, muhahaha
i think thats call herpes bro.
home made shorty antenna, gas pedal mod, weight reduction, home made CAI, home made cat deletes, longer seat tracks, rear seat deletes, windshield-rear-view-mirror-swap, AC delete, cutting stock springs
all cheep/ free junk. ;-)
C
Cox98Gt
Ga
all you need is a testlight, butt connector, and krimpers. 1. take center consol box out (screws are under rubber bumpers.) then take fog light switch out, there is two taps to push in. then take test light and find the power that is connected to headlight switch(by pulling it on and off) then take the empty plug that is in the bottom of the box(convertable switch) then find the power to that. You have to turn the ignition on. then double check both after that. cut the two wires, splice and but connect. then reconnect the switch turn ingnition on and look at your work. before you put it back together. here also helps. http://neptune.spacebears.com/cars/stories/foglight.html
C
Cox98Gt
Ga
Lol desertcox is my dad notice the COX, last name. and i have thought about the shorty antenna
C
Cox98Gt
Ga
ohh yea when i did my fogs i put some brighter bulbs in they are 100 candles power. got them from napa. i can actually see them on the ground.
DropTopPony
South Jersey
Good job!
My suggestion for the next round of semi cheaper mods would be sub frame connectors. They aren't that expensive to buy and having them welded in isn't that bad either but the results are well worth the total of under $200.
C
Cox98Gt
Ga
yea that and a strut tower brace would be nice. got so save the mula first
