my latest addition!
While finishing this project I realized that my stang is more show then go and will now focus on the motor this summer. I always hated the way they factory rubber boot on the parking break tore and looked bad so I decided to swap it out for a leather on like the 03 cobra from redline shift boots. I had been considering adding racing stripes and continuing them through the interior and decided to pull the trigger.
http://www.cardomain.com/ride/2395420/5
I had to replace my heater core so I took care of swapping and painting at that point. I first painted the panels gloss black just to freshen them up a bit. Then I painted the green stripe that will be between teh black racing stripes down the middle of the dash starting up at the clock/radar detector and then continued it down over the shifter.
Trick flow heads are on the way now and just need to find a cam and someone to help me install them to get the motor caught up to the looks.
wnracing
You get that from Redline? I've considered getting a setup from them for a while now, just never been able to pull the trigger.. Definitely on my list, just a little more in the future.
Looks really familiar, did you post something about this a while back? Looks good regardless.
yup, redline did a good job. I was even picky about matching the green stripe to the paint and his samples green was more olive then DFG. I did some searching locally and found a better match and sent a swatch to him. He put my piece in and the match was about as close as you can get between metalic paint and leather/vinyl
I posted pics of it when it was not finished and mounted a couple of weeks back. I had been too busy to take pics of it finished and installed so I did it today. I also painted the piece that covers the windshield vents just under the windshield but forgot to take pics of it.
I also realized I cleaned up under the hood and forgot to take pics so I will update both of those tomorrow.
beuchaw94gt
Thats looks killer!! Just enough to set it off but not over kill and very orginal. Keep it up make!1
That is exactly what I am aiming for, thanks. I like visual mods that do not scream at you but when you notice them they want to to look a little closer.
