my new rims! (titile changed)
silver 4.6
Guest
hey all, i know some of you have massive tires without tubbing the wheel wells or other extensive surgery.... ive found that 10.5 is the widest you can go without wheel rubbing (i think)...
does anyone have a complete rear shot of 10.5 width on a 94-98 stang?
or, if you dont have a pic but own 10.5 rims, do they rub on the wheel wells, or do they fit fine?
96gtchinook
Re: 17x10.5 rims
i have 315's and im not rubbing, but i removed the quad shock and im at stock ride height on the rear.
97npi
Re: 17x10.5 rims
I wanna know the same thing except i am lowered 1 inch.
silver 4.6
Guest
Re: 17x10.5 rims
So you guy's suspension is stock, and you habe no probs? Cool. Thanks.
Cruizin GT
Re: 17x10.5 rims
They will fit no problem, only thing you might have to do is flip the quad to gain clearance. Or better yet, get some MM LCA's and remove the quad.
silver 4.6
Guest
Re: 17x10.5 rims
flip the quad... couldnt tell you what that means, lol. i only know that people are telling me they fit with it in stock position.
on another note... i have more wuestions about which rims to buy.
im looking at deep dish 17x10.5 in the back, and no dish 17x9 in the front. does that sound good?
second off, if i buy tires, i cant find sumitomos that match the rear ones, at least in tread pattern. is that a concern?
joekd
Ct
Re: 17x10.5 rims
You don't need to match front and rear treads or manufacturers
Flipping the quad shocks is exactly what it sounds like, you unbolt them and flip them over so the large side is facing the other way.
Cruizin GT
Re: 17x10.5 rims
+1 ^ not hard to flip em if you need too, as far as tires just keep em in pairs. ex. front pair, and rear pair. can be different manufacturers. And the rim size is fine 10.5 rear 9 front, is pretty common.
silver 4.6
Guest
Re: 17x10.5 rims
anyone have a write up of how to flip a quad shock? idk where the crap there even at... suspension isnt my thing.
joekd
Ct
Re: 17x10.5 rims
Jesus, just crawl under your car and you will figure it out. Look at your rear end, you will see the normal shocks going up, quad shocks are the sideways ones. Again, unbolt both ends, flip them, rebolt.
It seriously is that easy.
silver 4.6
Guest
Re: 17x10.5 rims
It might be seriously easy but all I'm trying to do is figure everything out before I mess something up.
I looked at them and there the little sideways shock things bolted to my frame on one end.
Re: 17x10.5 rims
that's the quad shocks.
option is to remove them completely (mine are removed), or unbolt, flip, reinstall
nrk
Re: 17x10.5 rims
sumitomo 315's, no issues but i'm still at stock ride height also.
Cruizin GT
Re: 17x10.5 rims
Yup, that's them. As COX said you can either flip 'em to gain a little clearance, or remove them. If you remove them, you might get wheel hop, some do some don't just kinda luck of the draw. If you get wheel hop, your best bet would be to get some MM LCA's and that will fix it.
silver 4.6
Guest
Re: 17x10.5 rims
alright, im not the type to be doing burnouts or hard acceleration, (paranoid about breaking things).. so if i do remove them, i shouldnt be running into wheelhop anyways.
thanks for the pic, nrk. did you flip your quads?
joekd
Ct
Re: 17x10.5 rims
Sorry if I sounded harsh but wasn't I right about seeing them as soon as you crawled under there? As you can see they are bolted on each end, unbolt, flip, rebolt, done
silver 4.6
Guest
Re: 17x10.5 rims
cruzin, its cool, i just know that when i touch things they normally getted messed up and and i have to give 'ol dad a call, lol.
i took off my wheel and flipped them an hour ago, no issues. i took pictures and im going to do a write up of how to flip quad shocks.
hopefully i can contribute something to this site instead of just taking up room :p
