My swap 89 block into 95 sn
green5.0guy
Harrison, Michigan, United States
Ok just making sure be for i send my 89 block out to be machined, i want to know if its going to be a waste of time since its not a "H.O" block.... i have heard an read on some other forums something about aftermarket pistons not working because its not a original H.O block this will be my first time building a motor and i just need to get more info on it thanx please let me know ASAP :)
945.0
Milton, Wisconsin, United States
talk to your shop thats doing the work if they cant answer simple questions than you should not go to them. if you want a knowledgable shop and person call pakes engine and machine in janesville,wi talk to bill hes got a sn95 5.0 and really knows his shit 608-758-9003
945.0
pistons are matched to the bore. the block is bored to what you want example .010 over... shop bores block to spec then they take the piston that you want and fit to the bore by honing the block and giving block the clearance it needs for the piston and rings that go into it.
when you say "aftermarket pistons wont work cause its not a ho block" makes no sense at all to me. that sounds like someone just saying it to say it but im not fully sure. just my opinion on that issue
green5.0guy
green5.0guy
ok thanx man im most likely going to livernios performance here in michigan idk if u have ever heard of them but i guess they have really good techs and everything else they also have in house CNC machines an what ever so idk i have alot more reasurching to do lol
green5.0guy
green5.0guy
yea i get the bore thing i want to go .30 over to make my 302 a 306 then go from there like i said its my first one and i basiclly have to go slow an make sure everything is in sync and its perfict
945.0
what bore you want? pistons? more details please. plus you will also need to make sure that the piston to head clearance is there. i mean that you dont get to tall of a piston and smack the valves with it. theres a lot to look for when building a performance motor. once i had a sbc built and the pistons i had needed more bore clearance due to them being a "tighter piston". this is what the other shop had to do after the first one did the work. the machinist was an expert with the piston brand i had
green5.0guy
green5.0guy
i want to bore .30 over and go with diamond pistons and eagle rods thats the basic right now im going to buy a forged crank and then for the top half i want to do TF twisted wedge heads and either TF upper n lower itake or a GT40 intake is there anything i really else need to worry about ? because remember since its not a actual 5.0 block nothing is forged
945.0
forged is good for boosted apps. you could go with a rotating assembly from eagle or scat whatever you choose. the TW heads do some research and compare. i have turbo swirl heads myself. dont rush into getting the block worked on take your time talk to the shop make sure youre 110percent sure that "this is what i want and how i want to build it". takes hard earned money and time. you dont want to put 2000 bucks into a motor and all said and done youre unhappy with it cause lack of performance, clearance issues etc... many things to consider take your time research and asking ?s is best you can do before possibly making a high dollar mistake. or the biggest achievment of building your first motor and liking it
LAFENATU
The difference between the H.O. vs the Non-H.O. is the firing order.
High Output came in the mustang where the Non-H.O. came in cars like the Lincoln etc., the block is identicle.
green5.0guy
green5.0guy
yea im deffitly doing tons and tons of reasearch and im finding out new things everytime i click on something different so all in all i hope it works out and ill have another nice SN on the road
if i have any questions ill post them on here cause its pretty quick respons and what not thanks again for the help
