Need Assistance ASAP
96redgt
Charleston, SC
I am stuck at work because my 96 GT has decided not to crank. When I turn the key to the start position, the car clicks and dies (kind of like a dead battery). I read the voltage of the battery, and its sitting right at 11.98. I'm thinking it may be the factory anti theft system, but i'm not sure. I need some help on the subject so I can get out of this place! Any ideas on what to look for to diagnose the problem?
And on which side of the motor is the starter? I can't see it from looking under the hood........
Blk97GT
I believe the starter is on the passengers side under the exhaust manifold? If the car is clicking I think thats the sound of a bad starter, someone correct me if im wrong. Give it a few taps with a small hammer or a wrench and try to start it.
96redgt
96redgt
Charleston, SC
Got it running. A couple of guys I work with helped me out.... It was a corroded negative battery cable. You wouldn't believe how corroded that thing was... Thanks for the help guys.
AaRoN
King Post Whore
I just replaced my corroded negative cable not 6 months ago. Glad you got it running. Make sure you change it though.
96redgt
96redgt
Charleston, SC
Yeah, I just slit it back about six inches until I found good copper, then I cut it and attached it to the connector. I'll have to replace it before too long, or its gonna bug the hell outta me. How much of a pain is it to replace it?
AaRoN
King Post Whore
It's easy. Took me about 5 mins.
GDTrumbo
Nashville, TN
Replace the whole cable. The clamp-on terminals are crap! Might even do the pos. cable as well.
GT
96redgt
96redgt
Charleston, SC
Sounds like something else to do besides painting the calipers this weekend... If its not raining...
Thanks for all the info!
96redgt
96redgt
Charleston, SC
Question: My car is starting to get hard to crank again... I haven't gotten to replace the big ground wire yet, but when I checked it, its fine (still nice and shiny copper). The smaller wire that is attached to the clamp is completely corroded, at least 3 inches from the end. It runs to a connector, along with another black wire coming from the neg terminal. What is that connector for? Can I replace the wires running to it somehow or do I just need a new connector?
