Need help blue smoke!!!!!!
tommybunz
Need help blue smoke coming out of xhaust and into cockpit after i run it hard. new motor well 350 miles or so.
Paul
White smoke is coolant. Blue is oil. If my old failing memory serves anyway...
RJayLo
ahhh lol.
I knew it was one of the 2 and 50/50 says I guessed the wrong one. :hammer:
Big thumbs up for spreading wrong info in the first post!! :crying: :wall:
T
tommybunz
i know its oil but im not sure how to fix it. did the pcv, oil air separator, new valve seals, lil leak @ valve covers but dont seem like enough to make that much smoke idk.
Paul
Cylinder pressure will vary, but it's important that the readings are all close to eachother. Do the test and come back with the results.
T
tommybunz
just buy a gauge take out each spark plug, screw in the gauge and then turn the crank right
Paul
Yes. You can unplug the coil and just use a starter bump tool if you have one.
T
tommybunz
thinking about trading it for a pro-m or something, dont think its doing me real justice
