Need Help!!!
BigginSN95
hey yall i got a 95 gt its missing and its not ideling right or sometimes not at all. My mods are cai, pulleys, 75mm throttle body, tfs intake. ive replaced distributor car rotor button, plugs, plug wires, tps, iacv, ignition coil. Check engine light comes on but it do read a code at auto junk(auto zone) ive done about all i know what to do i need some help, its my dd. Any input would be appreciated thanx.
x182dan
Autozone will not read your codes since you have an OBD1 car. They will only know how to do OBDII. You can do the paper clip trick or you can buy a scanner for under $100 that will scan obd1 codes for ya. You might want to check out your balancer, they are common to go on 9495s and can really make your car run like crap.
eliyarbrough
Nocona, TX
My car was running like crap on 7/31/06. I had a full tune-up done, still bad. I then had my MAF checked. It was that. Ran like a champ from then on. Check that.
i dono if this is the problem... i dont have alot of 302 experience, but could it be the crankshaft positioning sensor? my uncle's minivan was giving him very simular problems and that was the issue.
i dont know if your car has a CPS, or anything like that... but i thought i would put that out there for the brain-storming-session. :)
also, clean your intake air temp. sensor with MAF sensor cleaner.
B
BigginSN95
it misses all the time especially under a load. like bottom of 3rd gear and bottom of 4th goin slow, but it misses all the time. the mas air is fairly new i had to replace it about a year ago it doesent feel like the mas air is bad. it feels like ive got a dead cylinder. thanx yall
MustangChris said:
our cars are dinasours. no crank sensor, no cam sensor.
do you have a haynes or chilton manuals. they tell you how to pull codes with a paper clip. and also give you the code meanings. you need one anyway if you plan on turning your own wrenches.
you could also be looking at the pip in the dizzy going out. reman dizzy $120 with warentee, replacement pip $20 and you do it yourself.
