Needing some assistance with what I feel to be an ignition issue.
Blakonblak94
Blakonblak94
Ok new coil, new rotor, new tfi, new pickup, still cutting out. I'm gonna put my factory fuel pressure regulator on and see if it's messed up. This sucks.
Blakonblak94
Blakonblak94
Will do. Here is a question on grounds. If I have two different grounds on one screw will that cause any issues? I had an ex-service tech go for a ride along today and he said it wasnt like anything he's ever dealt with before. Ill be able to video tomorrow.
mikey94gt
No, dont worrry about that. you do need to ground your engine to the negative terminal on the battery, along with the engine wiring harness and ECM
mikey94gt
Blakonblak94 said:
Are you saying add those grounds? All factory grounds are still intact.
Then your good. I would do a compression test, that sounds reasonable.
Blakonblak94
Blakonblak94
I just pulled all my plugs, they look pretty bad, and when plugging one of the plugs into the coil wire the spark was orange and not consistent. Shouldnt the spark be blue?
Blakonblak94
Blakonblak94
I was running autolite 3942's but i bout some motorcrafts a few minutes ago to try. Still the same issue. Im hping the video works.
Blakonblak94
Blakonblak94
I know the video works but I do apologize if it actually takes yall to my page. My photobucket is acting an a*s. Correction it should work just fine. Here is one other thing I noted today. If I unplug my maf it still funs the same as it does with it plugged in. Like identical, the idle and all. I wonder if it could be a culprit? I may swap back in my 19's and maf tomorrow just to eliminate that from being a possibility.
HISSIN50
Did you ever happen to run a cylinder-balance test (after pulling codes)? If so, it should have let you know about any cylinder(s) not contributing properly.
Blakonblak94
Blakonblak94
From my reading I feel it to be a bad Maf. Seeing as how I unplug it and nothing changes and the missing only occurs at wot which would mean it is dependent upon airflow through the Maf. I'm gonna give it a shot after work. If it is what should I do? It's a 2 month old pro m.
Blakonblak94
Blakonblak94
Ok, so Im not even sure anymore. Swapped in my old maf, with my 19's and the car did the same thing. Wondering if my computer is done now. Im just so lost. This has sucked and I cannot for the life of me understand why its doing this.
Jerry santos
