Needing some assistance with what I feel to be an ignition issue.
Blakonblak94
Blakonblak94
So the flaw has to be in the wiring somewhere. Ive replaced just about everything I can, and the only thing I can think is that something is wrong with the wiring to the MAF. Im not exactly sure what to test but I intend on trying to find something this afternoon.
Blakonblak94
Blakonblak94
Ok so here is the last question for this thread I believe. What are the chances that my computer is bad? My maf is recieving power, ground is constant, and it is sending signals. Both sets of injectors are operating(19's and 24's). My tps doesnt have a dead spot. All ignition components have been replaced, except for plug wires. Put back on stock regulator, so its not a fpr issue. This is getting funny and now my throttle response is getting to be an issue as well.
2002BLGT
Bedford VA
Whats your base timing set at ? Did you replace your Harmonic Balancer ? Sounds like timing is off to me after watching the video
Blakonblak94
Blakonblak94
Balancer is still original. Timing is around 10-12, marks are a tad hard to read. I assumed timing was off as well. But it runs pretty well. But now it has lost power accelerating and stil acts like a rev limiter around 4000. Could my balancer have spun that bad?
HISSIN50
I misread initially - I thought you had new plug wires. Have you checked them for leakage and proper routing? It's possible for there to be an inductance crossfire (there was a TSB about it during the aero fox years IIRC).
Adam95GT
Your changing alot of things besure to keep track. Usually just throwing on lots of parts can start new issues.
HISSIN50
Blakonblak94 said:
Can you tell me how to check for leakage? They are factory ford wires.
One way is to pop the hood at night and start the engine. While being very careful of moving engine parts, the risk of shock, burn, etc, spray the plug wires with water from a spray bottle and look for light leaking from the wires or sounds of spark grounding.
dsg gts
i went through the same exact stuff you are now going through.i did all kinds of stuff to mine.replaced dist,coil,computer harmonic balancer ,ect. i had a tune in my computer it was a sct tune. i pulled out the chip. car ran perfectly. it still runs great. it is back to its old self. 12.8@118. 311horse to the back wheels.i rebuilt the dist.and then went and bought one off of ebay. the last thing was the computer. i put a stock one in and that cleaned it up.
dsg gts
i have a 91 short block with trickflow h/c/i.bbk long tubes bbk x pipe,flowmaster dumps all of this is with 2 1/2 in pipes.stock ignition stock coil . my timing is set at 12. factory computer. 5 speed. full length subframes,aftermarket control arms, bbk coils. tokico struts/shocks.in my 95 gts. The car weighs 2900 lbs.it also has 2002 gt brakes on it.i run nittos all of the way around.just so you know what i have in mine. im assuming yours is close to mine.any questions let me know. by the way i went through 6 coils before i got it all figured out.
Blakonblak94
Blakonblak94
Well I played with it today. My balancer has spun. I have my timing set around 20 according to
The balancer no knocks or pings. It's
Back in running order. Thanks everyone. I'm hoping to be able to go get a tune now.
mikey94gt
Blakonblak94 said:
So I checked my balancer today. It wobbles more than a one legged alcoholic.
Thats not good... that will cause major engine damage if left alone.... mostly destroying your main bearings. it could be causing your high RPM misfire, but I dont think so....
Blakonblak94
Blakonblak94
The fact I couldn't time it correctly was causin the issue. It was basically 10 degrees retarded of
Where it should have been.
2002BLGT
Bedford VA
I could tell it was timing from watching the video , man I should be working at a Ford dealer instead of a Dodge dealer LOL
Replace the balancer ASAP before you end up doing a crankshaft with it
mikey94gt
or a Professional Products one, make sure you get the spacer too. < I run this, and they last a bit longer than the stock ones. call Summit....
Jerry santos
