New Pics Blackout!!!
Zackqb2
I'm finally blacked out. Letter's bottom bumper trim, and tail lights. Tell me what ya think! :thumbsup:
Looks great man...nice work on the tails, they look very glossy.
Is a black top in your car's future? One of the best mods I ever did was go from a tan top to black.
Z
Zackqb2
O yea 4 sure. I am looking to get that next and a O/R X Pipe.
Brian95SVT
Chesapeake, VA
Now if you don't already, pick up some black beauties or some smoked headlights, do the black top like you said you want to and man will it be looking GOOD!
I like the tinted tails and the black lettering!! It's coming together very well.
Z
Zackqb2
Win said:
Which method did you use on your tails..... Looks good man
well I just cleaned them off scuffed them up a little took then sprayed 2 coats of vht nightshade it looks great at nite to
Z
Zackqb2
Well can the nightshade work for the headlights 2 just 1 coat would be good
Looks sharp man, black top will really tie it together.
using VHT for headlights is frowned upon, apparently it messes up the light beam pretty good. Just get smoked headlights, they look sick.
dafizuck
I did it to mine and can see great with my 8000k HIDs... but I didnt install them before I tinted them so I dont have a comparison. Maybe I need to consider new lights.
dafizuck
OnyxCobra said:
i'm glad someone had success with it, probably less noticeable with HID's
I did four VERY LIGHT coats and seems to be perfect...
Z
Zackqb2
Thanks for the input fellas I will spray the headlights 2 morrow and post some pics of the lights
kintek
black outs look great man, if you havent pulled the dealers sticker off before. a easy way to do it, is getting some spray bottle fill it up with some adhesive remover and spray on it really good, "gently" slide a razor blade along the lettering and it will come right off. If you push down and in you will slice the paint and pull it up. I did several times at the dealership to brand new cars, even the "challengers" and it worked perfectly. You can go back over with more spray and a super soft cloth to rub off the extra adhesive, just keep adding spray and dont rub to hard either.
Z
Zackqb2
well I did the headlights and i would never recommend it ever the corners look OK but not the lights. I'm going to get some stuff to remove the vht
