New project and 2 questions
Tim300wsm
I just got my cobra yesterday. The previous owner had the head gaskets done, new radiator, new water pump new thermostat. It runs hot in traffic/ low speed but is fine at highway speeds. What could cause this? (Searched and couldn’t find answer but I may be an idiot)
2nd issue is it has a tick at idle and not under load. Under load it disappears. Oil pressure shows good on gauge
cobrajeff96
Germany
Chain tensioners are usually the cause of the idle tick, it's chain clap. Multiple technical service bulletins have been made by Ford over the years in the newer engines. What can cause it is negative travel in the tensioners or just low oil volume in the pan. Earlier mod motors didn't have good drainback to the pan to begin with which was certainly fixed in the current Coyote era. But again, Ford's tensioner design has always been 'good enough' for general production (but not good enough for us). There are fixes for it, namely MMR has spacers that limit negative tensioner travel which requires a lot of disassembly and maybe is not worth it if you can live with the ticking noise. Just don't be bouncing off the rev limiter standing still in a parking lot or something. A loose chain always has the possibility of jumping sprocket teeth and that's one of the most undesirable things.
Stack washers behind the chain tensioners piston with the long chains. Takes a little trial and error to get the tension right.
Probably last around 30k miles before readjusting, but if you suspect youll ever be on the rev limiter often, itll save your engine.
Tim300wsm
Tim300wsm
My main reason for buying it is to autocross it so I will need to fix it
Venompower
Batavia, IL
I'm going to suggest burping the cooling system at the cross over... between head gaskets and radiator the coolant would have needed to be refilled, and you may have an air bubble in the system.
hopefully the gaskets were put on correctly and none of the water outlets were blocked
and thats hard to tell because the heads are installed
seen that mistake many times
Tim300wsm
Tim300wsm
Yeah I would really hate to do the head gaskets 1st thing
chasingomas
