I love your rack!!
The tie rods look stainless, are they? I will consider switching from my flaming river rack if they are. Mine is already rusting.
98snakehorse
98snakehorse
Southeast, IA
Just ordered my fuel tank and new pump setup.... I just spent some money on this but I think it will be well worth. BBRC ftw!
98snakehorse
98snakehorse
Southeast, IA
What is BBRC?
http://www.behindbarsracecars.com/
This is the tank and pump I got -
evilcw311
Most Evil Member!
Louisville, KY
So you say you paid about half?! You gonna explain how?!? Lol
Just out of curiosity, that’s a lot less parts for about than same price that you can get a complete kit from Glenn’s. Why did you order this specifically?!?
50HSN95
Minnesota
I was thinking the same thing :D, for half that price I would be interested in one also!
98snakehorse
98snakehorse
Southeast, IA
First I’ll get to the why this particular kit ... 1. I already have all the fuel system in place from the tank forward. And this unit will bolt right into place using my current filler neck and fuel level sender. 2. Look how nice and shiny it is. 3. It’s an 18 gallon so will be beneficial while running e-85 and has great baffling which will benefit when fuel levels are low.
How did I get it cheap? Luckily I found an individual who had a brand new never installed one that ended up going mini tubbed and had to change direction on the tank setup. So now for what I paid is just a few hundred more than what the pump itself goes for.
SonicbluGT
new guy here from another forum. loving the build looks awesome! dont see to many cool mustang builds around iowa anymore
98snakehorse
98snakehorse
Southeast, IA
Test fitted the tank in this weekend. Fits great. Just gotta swap the feed an return lines with some 90° fittings and will be good to go.
97stanger
-8 Feed and -6 return. If could go back I would have atleast done a -8 return too.
Yeah -6 is pretty small for a return. On my old setup I was 8/6, im sure you’ll be okay, anyway to just adapt from 6 to 8 fitting and run 8 line?
98snakehorse
98snakehorse
Southeast, IA
Yes, I think for my current power goals this will be fine. I do need to switch out the crossover fuel line at the rails as the one thats installed by MHS was only a -6. Not sure why he did that.
98snakehorse
98snakehorse
Southeast, IA
All update.... havnt done alot with the car yet. Decided to strip back the engine harness and do some more wire tuck type stuff. Should have a cleaner engine bay this year. Also regarding my core support.....
There is a company Motion Raceworks somewhat local to me that is developing some custom lower bolton/weld-on Core Supports for the foxbody and sn95 market. These alow us to move the radiator forward and also has intercooler mounting brackets for the Treadstone intercoolers. The foxbody supports are currently available now. I just spoke with one of their employees and they will have the sn95 units in production in the next couple of weeks.
https://www.motionraceworks.com/
98snakehorse
98snakehorse
Southeast, IA
Quick update where we are. Brake system is plumbed and bleed and ready to go. My front core support I ended up having my buddy just build me one and its almost complete. Getting ready to pull the engine to get the oil pan drilled and a drain bung welded on. I'm pricing my options to get a built transmission. Im guessing the stock t45 will have met its match with the new setup.
BMAC96GT
Virginia
Sounds good man! What trans are you thinking about? Built T45 or something different?
Isaac cerr
