O2 sensors
ninetyfivegtstang
Ok, my question is when do you know when the o2 sensors are out I just put in a new motor. Don't really know if I am getting bad mileage yet cause of new setup.
CanaryGT
Phoenix
Man i knew when mine went. It would hessitate and then all of a sudden SURGE with POWER!!! Well I dont have much power but yeah....
kawasakikidd
i just changed mine out.hoping for better fuel mileage.mine wasnt idleing good it would surge alittle,and it would stall sometimes i was told to change iac,and tps.i did a year ago it always did that until i changed my o2 sensors man i couldnt believe the difference it was throwing a code for about a month but even before it started with the check engine light it still would stall and idle rough.but all better now.baby runs smooth.good luck
ScottyDsntKnow
I'm thinking I may want to put some new ones in mine before I try and take it through emissions. I know the bosch ones are total ass so what is a good replacement sensor to buy that doesn't cost like $80 for each?
AaRoN
King Post Whore
The OEM Ford ones are the only ones worth the $$.
ScottyDsntKnow
Well, drove the car today, mileage was actually comparable to what the car got before I did the HCI so maybe mine are still ok?
2slo95fiveoh
Lawrence, Kansas
Motorcraft uses Bosch for their o2 sensors. my car was running very rough, misfiring, would run at what seemed like
20% of it's ability, and then BAM all of a sudden 100%... ran the OBD1 scanner and it said "bank 2 reading rich".
replaced both o2 sensors with OEM ford (bosch) and it runs like a champ now..
cdsmith_2002
My O2s were causing idle surge and stalling. They did this long before causing Lean codes. I bought Denso sensors from Jegs for about $46 each. They work great.
