Oil Filter Adapter/Cooler
Mystic1688
ok guys my oil filter adapter/cooler is leaking, anyone have any links or a good write up of disassembly/reassembly cannot find anything really excepts its a PITA and kinda straight forward!. Thanks in advance 96 Cobra 5-speed.
D3VST8R96GT
Marble Fall, AZ
D3VST8R96GT
Marble Fall, AZ
I wracked it with a rubber mallet.... not so easy when inside the car.... after that there are only 3 bolts that hold the mount to the block and that gasket fails and leaks so replace it while everything is out....
Youre better off junking it and replacing to the non cooler type. Be sure to get one from a mustang if you decide to switch it.
Mystic1688
It's a pouring at a steady pace it make's me think its from the weep hole but im also getting a slow drip of coolant. Ill be checking into it first thing tomorrow.
I have a 5.0 but i ditched my oil cooler and just bypassed it with coolant hoses, don't regret it at all.
Mystic1688
Alright thanks for the picks and info guys! hopefully itll be fixed by tomorrow!
Mystic1688
Alright thanks for the pics and info guys hopefully itll be fixed tomorrow!
Mystic1688
What year's are interchangeable? i just found out its trashed and needs a whole new unit id rather just do the swap. Anything to it drawbacks?
slow90coupe
Advance, NC
You're going to hate life when you try to get one of the bolts out of that oil cooler. That one bolt took me a few hours to get out, and that was with a tubular k member.
Mystic1688
Are you selling yours? I might want it! I was given a 03 mach 1 oil filter adapter just have to wait till it gets here i was told it will fit with no issues but looks like it may hit the headers.
I just drained the coolant and removed the oil filter shaft and it was alot easier than i expected. Had too since i was doing the upper and lower intake gaskets.
rlmobile636
