oil pump question??
Tylerdude17
ok i have a completed pi swap right now and iv got a bent valve or something wrong with the valve train so one of my buddys is giving me some extra pi heads he has got. he said that i should repalce the oil pump when i do the swap because they sometimes go out and dont make the oil light come on. is that true and if so what would be a good one to get?? i got the ford racing head changing kit for the first pi head swap, could i reuse the headbolts and head gasket on my new pi heads. i might have put no more than 3000 miles on the headgasket and headbolts. umm i already got new timing chains, all new seals from the heads up pretty much. with the new heads im got some comp cams 102500, and gotta order some bbk headers and stuff any one got any suggestions for any of this?? any help would be appreciated :laughing4:
Traidmarx
i'd probably start by trying to narrow down exactly what it was that broke in your motor and see if there could be another under lying problem that needs to be fixed. would truely suck to do the PI swap and fuck that stuff up to.
Willis_98GT
DFW Texas
102500s will run good,
im about to get 102600s
as for the oil pump your kinda limited.. you can use a 03/04 cobra pump.. or ford racing makes one, also melling.
T
Tylerdude17
well do i need one and it doesnt matter bout the heads i got on right now im going to fix those later and the problem only arose when i put the heads on so its got to be them its misfireing
DropTopPony
South Jersey
You put the heads on then bent a valve?
Sounds like you had PTV and the timing was off.
Stock oil pumps work fine for stock engines but if your upping the HP you might need more volume. The Cobra oil pump is better and has a bigger tube that comes with it. Consider forged gears for the pump also especially if you have underdrives.
T
Tylerdude17
i bought the heads from a guy who said he took them off because he floated the valves i asked around and every one said just replace the springs so i did and put them on and something else is fugged up so ya, the timing was off the first time but not now and whats ptv, and can i reuse the head changing kit???
DropTopPony
South Jersey
PTV = piston to valve contact.
The head bolts are TTY= Torque to yield and are meant to be used one time only. Same with the head gaskets.
lordgufi
the valves were probably bent before you even installed them. and when you started running the car it just finished the job off. floating a valve will almost always end up in PTV and even if it just barely tapped a valve its enough to bend it at the speeds that the motor was rotating.
head bolts are one time use. if you remove them. replace them. the 90 then another 90 deg stretch the bolts so your pretty much at the bolts breaking point.
if you want to be able to remove and re use headbolts i suggest you buy a set of ARP studs as they dont currently make head bolts for our cars ( odd ).
T
Tylerdude17
my new ones already got looked at by a shop so im gonna be good this time thank god lol and then after i get the old pi heads off im going to take them to the same head shop and then after those are done i will sell them
