oil pump question
Ninety8stang
Duh405
So i need advice on an oil pump for my rebuilt engine. I'm running PI heads with a set of comp270's. Should i upgrade to a high flow oil pump or should i just get a brand new standard flow? I have heard people having problems with the high flows but what do you guys have to say about them?
94-427
Just use a new ford pump, will service U for years, just like the last one did
duff daddy
I used a stock pump from 96 up till last year, now i have a cobra oil pump with VT Engines black gear set. you will be fine with just a stock cobra pump.
Ninety8stang
Ninety8stang
Duh405
I just went ahead and picked up a melling standard volume at my local parts store. Hopefully I wont have any problems with it.
duff daddy
there were a few clearance and tolerance issues that I know of with the melling but you should be ok.
vermilion
maryland
i agree with duff. MMR, Melling look to use machined stock casings with different material and/or treated gears. unless clearance and thrust bearing are out of tolerance, you should be fine. Get quality main bearings.
duff daddy
Jason your talking bout motor clearance im talking bout internal pump gear clearances and quality of machine work.
here is a TSS Billet Oil pump (very nice piece)
Facts:
Melling Pump Specs:
Pump to cover .002
Tip to Tip .004
Pump to body .010
Inner/outer gearset weight 1311g
Stock pump specs:
Pump to cover .002
Tip to tip .004
pump to body .005
Inner/outer gearset weight 1077g
TSS gears in stock new 2V oil pump housing:
Pump to cover .003-.004
Tip to tip .005
pump to body .002
Inner/outer gearset only weight 295g :thumbsup:
97stanger
I am going to have a 550-600rwhp build and I just went with a Cobra HO pump, tons of guys are running these w/ no problems
Ninety8stang
Ninety8stang
Duh405
haha thanks for the imput guys. i checked it out last night and didnt look to bad. Ive had a problem with melling pumps before in my old 5.0L but i found some shavings in the pan when i pulled the engine out. If i fry this pump im going to pissed. haha
