Oil pump replacement
RichV
CO
The shortblock is a Ford Racing brand new block, not rebuilt, new. I put in a E-Cam, GT40P heads, SN Cobra intake, and headers. The oil pressure was extremely high and 1st track session it ate a distributor gear. I'm changing to a standard volume oil pump.
Really don't want to pull the motor completely out. Read up on being able to swap the pump without yanking the motor. Any success with doing it that way?
framda
Naples, Fl.
Make sure your dist gear matches the cam. I can't remember which is which, but I do know that a roller cam needs a different gear then a flat tappet cam.
ivan12
Either pull engine high enough to replace pump or drop the entire K-member.
RichV
RichV
CO
Well, in my experience I had a rebuilt 306 with a HV oil pump, startup was around 60-70psi. Hot would go 40 at idle, totaly normal for this motor. I actualy ran this motor in my SN with the said distributor. No issues, I actualy overheated this motor.
So the new block with the same HV oil pump runs 85psi or so cold. But it does not seem to change even with the motor hot. One of the guys I race with builds motors, and his opinion is that the pump bypasses at 85psi, and it is allways bypassing, even when hot. That's why it never changes. I did also read up on people experiencing similar issues with HV pumps and this same block. I don't think it's a cam gear issue, but I'm not 100% either. I want to try the new pump, I think the gears started getting fubared right after I put it together.
