Oil Sensor Problems? UPDATE
Codycougar91
I changed my oil a few weeks ago, put the right amount in and everything was fine and dandy. I have noticed that when i park on a downward slope, and then turn my car on, my low oil light comes on, and not itll just come on randomly. I put in more oil, but that didnt help. and the dipstick shows the level to be full, so could the sensor be shot?
UPDATE:
Today, friday, i checked my oil level, and it was below minimum :sad5: So if my engine is burning oil, would that likely be a problem with the valve guides or soemthing?
DropTopPony
South Jersey
Re: Oil Sensor Problems?
It could be that, you must have a 96 as i believe we are the only ones to have the sensor in the pan. 97-98 didn't get it.
C
Codycougar91
Today, friday, i checked my oil level, and it was below minimum sad5 So if my engine is burning oil, would that likely be a problem with the valve guides or soemthing?
i've got a 96 and i have the same problem. sometimes the low oil light comes on and sometimes it stays off. idk whats wrong and i dont have low oil or anything. i think its a short somewhere.
danielson631
i own a 96 cobra and i also have this problem. i like to back into my driveway, bc pulling out is a PITA, bc people speed down my block. when i start my car it says low oil. i would imagine its bc the position of the sensor in the oil pan
Gregor185
New Tripoli, PA
i also have a 96 and have that problem...ford has a tsb out for this issue and i dont remember exactly what gets replaced...its really no big deal though so dont sweat it
greenscobie86
The Big Apple
I have the same problems.
My low oil sensor is on the fritz and my car has bad valve seals whic I will soon be replacing. My car eats approximately half a quart of oil every 1200 miles so I just check it periodically. The low oil light is just a PITA because it likes to come on when I park on an incline. It's really no biggie IMO.
