On3 Turbo Cobra!
R
rideorange812
When is it going to be complete? Progress is looking pretty good man. I passed by your shop today lol
i was outside when you passed, your car looks and sounds amazing on a side not. hopefully soon... i'm needing to build the rear suspension and rear end first.. and i need the money for the turbo system which is 2k and the fuel supply which is 2k as well... and before you know it will all the ods and ends it will be more... im hoping before christmas... although i may drive it this month n/a just because its killing me not driving it lol
slow90coupe
Advance, NC
Thanks man. Yea power adders get real expensive really quick! I'm looking forward to seeing it in person once you get it done.
R
rideorange812
haha tell me about it i already cleaned my savings account out i've been working on for 3 years to get this car done lol, my girlfriend was telling me how good you was at detailing cars maybe one day you can stop by and let me check out your car. it looks good but i never have time to stop in and check it out
R
rideorange812
Big update coming this week, got started on the engine today. Got the crank plastigauges and mic'd a .0015 which is about perfect for what im doing, torqued up the main studs and set the crank. Got the pistons mounted to the rods and will try to get the rings gap'd tomorrow and have the short blocked finished, arp heads studs are on the way and coolant mod, might see a motor in the car by the weekend, still need my stage 3 comp cams
R
rideorange812
file fitted my rings today to top .026 and bottom .024, checked the rod clearances, clearanced the pickup tube for the main studs and tied up the shortblock assembly... hopefully my head studs will be here quickly and i can get the heads on and get the cams dialed in and set this bad boy in the car
R
rideorange812
glad to see dad helpin out. great project! :)
yes its very useful having a dad who has worked in a machine shop in a build like this.
here is some new pics of the arp head stud installation and the car... rolled it out side today and washed it.
me installing the studs into the block...
URL]
just threw the intake on for fun
and my gf made this
R
rideorange812
Thanks for the kind words everyone. And just incase anyones curious here is the engine specs. Teksid 6 bolt mainArp main studsForged cobra crankForged manley rods with arp 2000 rod boltsManley 9.1:1 comp forged pistonsArp head studsLivernois springsComp stage 3 camsStock port heads and intakeMmr imrc deleteMmr fuel rail
R
rideorange812
New updates... My guy finally came in to degree my cams, I got my full rear suspension, ordered my 31 spline axle setup, welded my axle tubes, dropped it off for powdercoat, painted the underbody, got my 03 cobra seats in, welded in the torque boxes. I also ordered my xxr 521 black machined stagged 18" wheel setup, along with nitto nt 555 245/45/18 and nt555 dr 305/40/18. Next week I'll get my slps and drop my motor in and possibly order my on3 setup and glenns performance fuel supply.... I see the light!
Musturd
Nice build dude this things going to be alot of fun once back on the road
foofinator
What did you use on the underbody and why did you choose it?
I really need to hit the underbody of my 98.. The rubberized shit never dries, and POR 15 is expensive.. Great build btw!
R
rideorange812
foofinator: Fortunatley my car wasn't rusted even though it was in a field forever. it has like maybe two spots of surface rust, took a scuff grinder pad to it, sprayed a little krylon primer, and then scuffed the whole under neath by hand and applied semi gloss krylon spray paint, looks amazing!
foofinator
All while on your back on jackstands I see.. Champ for sure. It does look great, if it holds up, its a good option.
