Paint and prepping dash black
BlackCobra50
I'm just about to prep and paint my dash. Was wondering what I should do/use to prep it before paint and which black paint you all recommend I should use.
Thanks!!
BruhBrahBrad
Sand it a lil bit, rub it with some alchohol or brake cleaner or the stuff duplicolor sells, (I think adhesion promoter). I just used alchohol and brake cleaner, you dont have to use both. The Duplicolor vinyl and fabric in flat black is almost exact color as oem.
dafizuck
Adhesion promoter is in a rattle can that you spray on.. stuff works great but I dont know if you need it.
BruhBrahBrad
DESERTCOX05 said:
scotch brite grey pad instead of sandpaper.
Sandpaper is fine, also. Just dont use too low of a grit. Im not sure you would even need it if you got the surface clean enough. I just wanted to make sure it would stick.
BruhBrahBrad
dafizuck said:
+1 but I was originally thinking of a prep wipe.
