For Sale Parting Mach 1 Ohio
full force
2003 Mach 1 and have tons of parts here... plus other cars...
Here is list of things I researched so far and my asking prices...will ship most items but big parts will be pick up only Olmsted Falls 44138 Ohio.
Aluminum Block 250.00
8 bolt forged crank 400.00
Heads:TBT need to see what spark plug
Complete upper and lower intake and throttle body 400.00
timing cover 100.00
Accessories and pulleys 150.00
Throttle cable with bracket 150.00
Fuel rail 90.00
COP Valve covers 100.00
CoILS 75.00 for all 8
Coolant crossover 100.00
Injectors : tbd
Engine wiring harness from injectors to ecu 150.00
3650 transmission rebuilt with 1000 miles, no shifter 600.00 p/u
Shifter:tbd
Hydraboost system 200.00 with all lines
Air intake and shaker scoop and brackets 400.00
Clutch 1000 miles :tbd
Flywheel 50.00
Driveshaft 50.00
O2 sensor and trans wiring 120.00
Under hood and headlight wiring 100.00
Dash harness 125.00
Body wiring harness 125.00
Ecu 150.00
Abs pump 100.00
Complete front brakes with spindles, drilled rotors and calipers 400.00
Exhaust manifolds/headers 125.00
Wheels and tires cobra r style aftermarket good tires 550.00 p/u
Seats driver has wear, with tracks 450.00 picked up
Dash 150.00
Mach1 cluster 125.00
Airbags driver and passenger with module 200.00
Door pulls 50.00
89slowgt331
on the 95 gt I am looking for a fuel return line from the rail to the fender, 94-95 crank pulley and a battery try and hold down.
CRAZYHORSES
HOUSTON / SPRING, TEXAS
Can a passenger side ground effect from the 95 be shipped reasonably to 77373? I'm also needing 1 of the retainer radiator shroud hold down things that are under the hood. I can text a pic latter showing what I'm talking about. Do you have any of those?
Thanks
