Pi cams
voidfinger
Hey guys. One quick question. Say that i had a bone stock 4.6 npi and installed pi cams in it with out the pi intake. Would i pick up anything?
Would would be a good estimate of the added fly horse power and the wheel horse power? Thanks
scarface
Guest
you would gain a bit, but as cheap and easy as the pi intake is, you should do both to take full advantage.
spitfirees20
why was mine edited, who in their right mind would go through all of the trouble to do the pi cams and not do the simple intake swap? that doesn't even make sense.
scarface
Guest
because we are a forum for people to ask questions and not feel flamed about doing it....had you worded it like you just did, I would not have edited your post.
V
voidfinger
just for reference, i have the pi intake on my car right now. Only thing is that if it gets totalled out i won't get it back. I just got a set of pi cams sitting at the house. Thats why i asked. thanks
1996mustangGT
are you still thinking about the 5.4 triton...?
if so i would keep the cams and intake and oyu'd probally get
more outta selling them both than individualy...
just a thought
scarface
Guest
put them in then O0
DropTopPony
South Jersey
you would still gain 12-15 rwhp with the npi intake...i've actually seen that dyno chart before way back in the day before we knew how restrictive the intake really was. We were brainwashed to think the heads were the 100% restriction compared to the PI engines so we were swapping cams not intakes...boy were we all surprised when those guys on TCCOA did the PI intake swap.
did you crash your car?
V
voidfinger
yea , my girl friend hit me in the rear going like 30 and it knocked me into the car in front of me.....damn nissan brakes locked up.........told her to watch the fucken road and not f with the radio, but o well.
Yea the body shop called and it looks like they can fix it....but the estimate is way off.... for instance
the insurance said that my "original ford" cobra bumpers replaced and painted would cost : 3XX for the front, and 2XX for the back..... cheapest i found the "original ford" stuff was 7XX for the front and 4XX for the rear.
Well i don't know about the rest....just got my fingers cross.
MustangMatt96GT
If I were you, I would do the PI intake to compliment the cams! Its worth the extra money to use with those cams!
LI98GT
Long Island, NY
For me the PI cams were worth more than the PI intake. The cams were ~12-15rwhp and the PI intake was ~7rwhp. To the point above, I did them in stages as you don't have to remove the intake to get at the cams and they don't get in the way, which is what I did. The old NPI intake stayed in place till I had the money to update it with the PI version. Shown below.... Man, I went so far, wish I went all the way and did the full headswap then.
V
voidfinger
scarface said:
he already has the intake installed, incase you guys missed that part.
Yea just seeing what it would gain on a stock npi car. Just in case and to see if it was worth the time and effort of swapping ya know. anyway i don't think they are totalling my car so that is a pretty good thing. :)
scarface
Guest
LI98GT said:
Yes. The springs in the NPI heads work with the PI cams, no problem.
right and wrong...they will work, BUT you need to change to the PI springs to take full advantage of the higher rev abilities (limiter must be raised also) you cant tach the stock npi valve springs out that high.
