pi head swap or complete motor?
Gregor185
New Tripoli, PA
so i bought a set of pi heads and just recently bought a block from an 01...my question is this, i have a 96 conv gt and i wanna do some sort of swap but im not sure what? i dont plan on putting on any kind of power adders but i do want a decent amount of power from the engine. what do you guys suggest i do as far as a complete motor swap or should i just take a non pi block and put the pi heads on? i dont mind doin some mods to the motors so thats not the issue but still... :icon_salut:
gt96stang
How's the npi motor doing?? compression and leak down test???
For me, if "I" were to do it... I'm swapping the whole motor... and adding a power adder...
But if the npi motor is healthy, swap the heads and go with the higher compression with some nicer cams, and have fun....
Willis_98GT
DFW Texas
1. do you want to use nitrous
2. do you want to use a blower later on
3. do you wanna cam it and pimp around?
mikey94gt
I just helped do a head swap and cams on a NPI 4.6, and it runs much better with the NPI 4.6 bottom end and PI heads. much better compression, it pulls hard and put the car sideways thru 1-2.
Gregor185
Gregor185
New Tripoli, PA
no poweradders at all...EVER...its a vert so i figure what for? even if i do use a npi bottom end im gonna rebuild it anyway to at least freshen it up
mikey94gt
I would do the NPI bottom end so you get the compression, if you are not doing poweradders, and a set of cams. If I was to do it all over with a Mod motor, I would save for teh Trick FLow heads, a nice set of cams, a Trick FLow intake and see what happens.
Gregor185
Gregor185
New Tripoli, PA
ok so i think im gonna pick up a npi block now and sell the pi block...anything you guys recommend that i do to the block or heads??ex. cobra crank or anything like that?
justinschmidt1
Yea, def. go with the NPI block if your gonna stay n/a, the compression bump is nice.
Would be a good time to do cams...should have some balls with the higher compression and a nice set of cams.
mikey94gt
If you are not gonna do any forced induction, you wont need the cobra crank or anything, just a nice set of bearings, possibly timing chains and guides, then put it together and drive it!!!
Gregor185
Gregor185
New Tripoli, PA
anywhere you guys would recommend for that kind of stuff? i mean i might do a lil bit to the motor to give me some power but im not gonna go insane
mikey94gt
well, I would take it apart and look at everything, if the journals look okay, i would order up a set of standard bearings with the full groove, preferrably coated. a set of Total Seal gapless piston rings for your stock bores, hone it out,(if they look good) put it together and have fun!!!
Willis_98GT
DFW Texas
helll yeah..
duff daddy
if you want some cams and ported heads let me know........ (see numbers in sig, i could sell you my set up)
atrainsgt
I would definitely go with the PI heads on a npi block. You will make a decent amount more power that way rather then just going with a full PI engine. Looks at Will's car. It's decently quick.
no power adder = 1996-1998 block with 1999-2004 heads. higher compression ratio.
other options with no power adder:
perhaps have the heads decked for an even higher compression ratio.
port and polish the heads for a "stage 1" upgrade. many companies offer basic CNC jobs that are cheep and effective (Livernois)
High compression pistons
atrainsgt
I was originally going to use 96-98 cobra pistons in my npi block. Now I think I will just get my heads decked a little since the gasket surface isn't great anyway, not that decking will help much because it probably won't.
depends on how much you deck. i doubt the amount you can deck with stock pistons will make a HUGE difference, but if you plan on keeping stock pistons, no boost, pump gas.... hell, i would deck it. lol.
vermilion
maryland
a nice set of naturally aspirated cams would help the compression do its magic. a basic gasket match port/polish on the intake and exhaust side will help them flow even better. the rough casting on them are nasty. if you plan to keep it N/A, flat top pistons would utilize the compression ratio the best. i also recommend to upgrade the fuel pump if it doesnt have it done. i think thats a nice setup.
