pi heads and wheel spacer question
GaryG
1) how big of a wheel spacer would i need to be flush w/ the wheel well using the '98 cobra wheels?
2) how much can i find PI heads/cams for? i dont need the PI intake, the GT already has 1
1FastGT
becareful with wheel spacers dude. i have a few buddies wheels fallen off cause of wheel spacers. there isnt enough thread to grab to keep em tight. if you wanna make em flush id suggest getting the BOLT on ones their more expensive but well worth keeping your wheels on. :wall:
96sohc
The small slip-on spacers are fine if you're using a small one, otherwise go with the bolt on with extended studs.
I've got a set of PI cams for sale, $75 to your door.
MustangMatt96GT
I have 3 inch studs so I bought the (hubcentric) bolt on spacers. I pounded out the studs, and was good to go. I couldnt find just the disks anywhere for cheap.
G
GaryG
yea i was gonna go w/ the longer studs, thanks for the info guys, i didnt know if the 1" spacer would make em flush, which is y i asked u guys
96sohc- ill keep that in mind, i may even just buy heads w/ no cams, and then purchase some xe270ah cams or something around there
2REDSTANGS
wow the wheels fall off. That must be a very strange and painful experience i would get sick if my car dropped onto the pavment while i was drivng that must get real spendy
Jerry santos
