piston 2 valve clearance
modo
Philadelphia, PA
that is a vague question without knowing what heads and what pistons...
lift isn't the issue as much as duration and cam timing is. when your valves are at max lift the piston will be at or close to bdc
Addermk2
total lift is not the determining factor in piston to valve clearance... its the valve timing events themselves, that cause the issues.
C
coupe5ohh
Phoenix, Arizona, United States
stock internals with ported nd polished gt40x heads with 1.72 rr with extensive porting on the upper and lower with 1 in spacer 75mm throttle body with calibrated maf for 24# and a tune and full exhaust is what my set up is going to be what do u guys think the best cam would be but keep in mind the cam is going to b paired with e7s for about a month
