Plastic manifold?
Daryl
Somis, CA
Scrolling through the old forum topics, a thought came to mind regarding the “weight reduction” thread. It got me to wonder: if so many modern motors (LS1, etc) have em, why not available for our pushrods? Only reason I thought of it is because the stock manifold has a little bit of weight to it.
Just spit-ballin…..
I am not sure they ever made a plastic intake for the pushrods, and if ya dig deep enough you will find PLENTY of topics of those intakes cracking/chipping/breaking. I will keep the weight of my aluminum intake.
shovel
The lower manifold has coolant and the thermostat housing in it, and more critically many small block ford heads have the exhaust crossover ports in them so a plastic lower intake is probably not on the menu.
For the upper manifold an EGR delete is pretty obvious but lots of people do that anyway.. beside that a plastic upper manifold is possible I just don't know that there would be enough demand for it, tooling isn't cheap especially when the finished product needs to meet a lot of requirements like heat resistance, oil and chemical resistance, gasket surfaces, threaded inserts, etc. that's a pretty high cost product to develop.
There is of course the option of having no upper intake at all
Mustang5L5
There was a few. All used the stock lower and were just an upper.
Hartman bread box, downs ford upper, and a couple more. All that basic form factor as above. Good top end HP, poor down low torque.
With regard to the long-runner style manifold, it likely comes down to cost. More than likely it would be a sacrificial mold type process to make one of those. In order to make it worthwhile, it would likely require higher volume. It's just a matter of what the numbers work out to be. At this point, the market for 302 products is shrinking. Companies are just focuses on platforms like Coyote's and LS-based swaps.
