ported windsor sr. heads vs holley systemax??? pics added
5.0kid
I probably should have put this in my last post, but just thought of it. I can get a used set of ported windsor sr heads (iron) for really really cheap, and was wondering if they would work better on my car than my holley systemax 2 heads. What do you guys think? You can definately tell these things have been ported. The previous owner went a 12.8 with these on a low compression 306 (8.1), f cam, and the typhoon intake ported on street tires. Just wondering if these would be worth it, or should I wait and just get my holleys ported?
here are the ported heads flow numbers (approx) http://www.kendrick-auto.com/dart_windsor_sr_ford_head.htm
Intake Port Test Results
Lift Previous CFM Current CFM % Gain Exhaust/Intake
0.050 38.3 41.1 7.4 71.8
0.100 74.8 79.3 6.0 74.4
0.200 127.1 148.6 16.9 81.0
0.300 175.3 184.2 5.1 78.4
0.400 213.9 237.7 11.1 75.4
0.500 234.7 267.4 13.9 73.0
0.550 243.6 285.9 17.3 70.0
0.600 246.6 294.8 19.5 68.4
0.650 248.1 299.3 20.6 68.4
0.700 249.6 301.5 20.8 67.9
0.750 249.6 301.5 20.8 67.9
Exhaust Port Test Results
0.050 28.3 29.5 4.3 71.8
0.100 58.1 58.9 1.4 74.4
0.200 115.5 120.4 4.2 81.0
0.300 122.0 144.4 18.4 78.4
0.400 154.1 179.2 16.3 75.4
0.500 168.0 195.2 16.2 73.0
0.550 169.6 200.0 17.9 70.0
0.600 171.2 201.6 17.8 68.4
0.650 171.2 204.8 19.6 67.9
0.700 171.2 204.8 19.6 67.9
0.750 171.2 204.8 19.6 67.9
and here are the stock holleys, which mine are lightly ported on the intake side to match the gasket.
Holley Systemax
Intake Valve Exhaust Valve Int 200 Int 300 Int 400 Int 500 Int 600 Exh 100 Exh 200 Exh 300 Exh 400 Exh 500 Exh 600
1.94 1.6 119 166 202 219 228 57 95 126 152 166 176
LAFENATU
Re: ported windsor sr. heads vs holley systemax???
I would just keep the Holleys for now.
blackpony
holleys ftw.... minor port work will blow those sr's outta the water....
5.0kid
well, i finally picked them up and they are actually ported really well. I only paid 400 for them so it was worth buying them either way. It would cost more than that to have my holleys ported also.
here are some pics of the ports, windsor sr on left gt40 on right (my holleys are about the same size ports.)
sorry the pics are so big, had to do it through cardomain and couldn't figure out smaller.
What do you guys think? The ports are extremely smooth, so much more than my holleys. I wouldn't switch them out till next summer, but thought i'd ask. Also, forgot to mention I may end up adding a vortech supercharger sometime next year also...
Matts50
I would have definitely stuck with the Holley's, FWIW. Higher ceiling and lighter weight.
5.0kid
^higher ceiling??? whats that mean? I'm trying to figure this all out. i may just end up selling them
Matts50
Ability to support more mods/horsepower.
LAFENATU
Keep in mind Windsor Sr. heads have a 2.02/1.60 valve so if you want to use any type aftermarket cam your going to have to clay the heads and notch the pistons accordingly.
5.0kid
yah, well my motor seized up on me today (broke a rod after 400 miles) :( so I'm going to go ahead and sell the smaller systemax heads and keep with the windsor srs. I don't have the money right now to spend on porting the holleys or i would do that. The holleys were some nice heads though...and i'm trying to sell them to fund my new motor.
96GTPlanB
