883cobra
I installed a new motor on the passenger window but now I have a new problem I cant figure out.The motor will roll the window up but it wont roll it down,using either one of the switchs.I can unplug the motor and use a 12 volt to roll it down which is how I checked to make sure the motor was good.
any suggestion on whats going on?could it be a ground issue or are both switchs bad?any advice on how and what to check for?I have a test light and a ohmmeter but I am clueless as to how to figure out whats going.
Thank you
Thank you
