Power wire
94 DropTop
Well i need to find a new place to get power from for my autometer guages. i had it wired from the cig lighter, but after 3 days of sitting the battery wont start the car.
94 DropTop
could i tap into my remote wire on my sterio? cuz the wire is already wired down that way.
ryclef331
You mean the blue wire off the back? You can but your gauges will only work when you have your radio on.
Mr. OAM
If you tap anywhere into your radio circuit it can cause noise or static in your radio reception.
Your best bet is to look at a diagram of your fusebox and select a switched power source that is not in use or for an option that you do not have that meets the amperage requirement of your gauges.
Steve
94 DropTop
my am/fm doesnt really work anyway i only listen to cd's or i could use the power antenna wire. Im back to driving it everday again so its no big deal now.
mcaligiuri
hook it up to a swtiched source, cig ligther is on all the time which is what killed your battery.
Jerry santos
