Purge kit question
BigSkySN95
I bought a purge kit and I came with a short brass tube which isn't nearly long enough to get out of the engine bay. I've noticed other purge kits have a clear plastic hose, is there anything special I should be looking for or can I just pick something up at the hardware store?
blown98gt
you can use clear plastic hose or you can use a rubber hose. I used a rubber one and had ran my dual purge to both of my air snorts in my hood. Then when i hit my purge it came out both of the nostrils on the hood.
blown98gt
no, I had this setup a long time ago but i can promise you it looks really good and is worth doing
B
BigSkySN95
My plan is to run the hose up front so the running horse looks like it's snorting. Don't know if it will work but I'll try.
blown98gt
better find a really good way to secure the hose to the horse lol.. there is a lot of pressure backing the hose to your purge so it's liable to set your pony running through the air :)
