Quad Shocks
94Pro-5.0
Little Elm, TX
i have always heard that if you have aftermarket rear control arms you can remove the quad shocks. my question is, do you just remove them? is it that easy, or does something else need to be done to remove the 2 extra shocks?
94Pro-5.0
94Pro-5.0
Little Elm, TX
i dont like it without them, so they're going back on, but horizontally swapped like i have read about on the corral
SRT Handz
yeah, most aftermarket control arms are not strong enough to handle the remove of the quad shock.... only the MM arms can because they are like "Super LCAs" :coolsmiley:
...even with my MM LCAs i left my Quad Shocks on... i might get some bilstein quadshocks....
vermilion
maryland
im son replacing mine with frpp or steeda. wtfever our ford racing dealership has. 33 a set or a piece. good thing i like about our stealership is they sell bbk or steeda products. the other one sells just roush which i believe is a rip off.
g_dogg
is there any advantages to getting aftermarket quad shocks?
i know bilstein makes some. anyone have them?
Hybridbird
I took mine off,even with factory arms in place and never missed them,even with the 315's and the clutch dumps.I have Roush lowers now and still don't miss them.I even took the brackets off, so I couldn't put them back if I wanted to.
1FastGT
i have upr upper and lowers non adj. ones would it actually do anything or is it like more mental then anything?
someone please provide links for some tech article.
g_dogg
"If your Mustangs is not equipped with a Torque Arm or other form of 3-link rear suspension, the quad shocks must be functional."
I'm quoting Jason from Maximum Motorsports.
fixthedoor
Chris from MM told me the same thing.
94IVGT
Northcentral, IL
ive got upr ucas and mm/granatelli lcas and no quad shocks. the bracket that the quad shock bolts to that is supposed to welded onto the rearend broke off and all.
1FastGT
Hybridbird
My story stands, neither one of mine have had them for well over a year with no ill effects,even on the car with stock arms.I also remember taking the "quads" off of all of my turbo coupes and the last one of those I built, 4 cylinder engine not-with-standing ,put 367 hp and 308 lbs of torque to the rear wheels on a Mustang dyno at Carlisle in 2004, so all my quads will continue to go where they have been going on my wide tire cars,in the shit can. :dancing6:
Passenger
x2. I've had two different brand of LCA's on my car and neither were from MM. Quadshocks FTL
g_dogg
some people have had bad experiences, like bending the torque boxes.
they blamed it on the removal of quad shocks.
