Question about programming a key fob
SnakeBite29
I bought a 1995 Cobra and it did not come with a key fob. I bought one off of eBay, does any one know how to program it?
poisonbl
Morgantown, WV
In the trunk, pull the driver's side lining and you'll find a 2-pin male connector sitting there open. Turn the ignition to 'on', then short those two pins. The doors will cycle locked/unlocked. Hold the 'lock' button on the remote until the doors cycle locked/unlocked again. Turn the ignition to off, the doors will cycle one last time. Finally, test the remote.
A handy video, not the best quality, but gives the key points:
[video=youtube;BAeowsKYydM]http://www.youtube.com/watch?v=BAeowsKYydM[/video]
9838stang
Minneapolis,MN
The way to do it is, you need either a wide flat head screwdriver or a paper clip, you need to peel aside the interior panel of the trunk on the driver side. there behind the panel, there will be a black box. that black box you should see an "opening" where there are 2 metal prongs. touch those two prongs together with the screwdriver or paper clip. u will hear the locks cycle. when this happens push a button on the remote most likely the lock button. u will hear the locks cycle again. once that happens take you tool off the metal prongs, and u will hear the locks cycle again. once that happens you remote is sync'd and you are all done
