Question about re-installing dip stick after BBK LT install
BigSkySN95
I'm having trouble getting this thing to fit right and bolt up to one of the header bolts. Anybody have pics of their install or tips?
94Pro-5.0
Little Elm, TX
i have bbk shories and it was a b*tch to get the dipstick on, and into the block. i'll get you a pic of mine tomorrow
ryclef331
I have Mac longtubes. I had to rebend the tube a couple times and the bracket is all sorts of tweaked. It bolts onto the valvecover now. As long as you don't have to shorten the tube, bend it however you have to get it to sit in the block and secure firmly and you'll be fine!
94kingcbra
I put a spacer and a long bolt on one of the header bolts, and just slid the notch in with some bending, use a clamp and a hammer to bend it that way you don't leave tool marks. Once you are all fitted up, get some high heat black spray paint. And paint her up. Nobody will even look at it twice and it will be solid as can be.
94Pro-5.0
Little Elm, TX
and make sure it is pressed into the block nice and tight, you dont want any oil dripping out :thumb:
916_5.0
I was able to get the tube back in after i put my shorties on but i had to do some bending but i cant get the dip stick in lol. So i only have the tube. I need t get that fixed cause it sucks not being able to check my oil.
94Pro-5.0
Little Elm, TX
my stock dipstick broke when i first rebuilt the motor. since then i bought a new one from ford. it doesnt go into the tube very smoothly though
916_5.0
Yeah i have teaken the tube out and tried to ram the dip stick through it but i think the tube is trashed cause there is no way i have been able to get it to work. I need to get one of another car, the tube of a 5.0 thunderbird should work right? ANd does anyone RTV the dipstick tube when they put it back in the block? i heard this is a good idea to prevent leaks there
Schiffy
Norfolk, Va
When we put the dipstick in around my buddies MAC longtubes on his 331, the engine was still in the crate, so it was easy, but that damn thing has more bends in it than the Tail of the Dragon(ask a Motorcyclist if you don't know... he should be able to tell you)
bany95
When I installed my BBK LT's, I re-bent the tube, removed the existing mounting tab, and built a little bracket to bolt the dipstick tube to one of the AC lines.... which is now a problem, because I just removed my AC system.
ryclef331
95-stang said:
I hear its a great piece of road, if your up to it. :thumb:
I LIVE in North Carolina and I still have never been....I wanted to take my lightning there back in the day. I'll go one day.
