Question for the Transmission Guru's
GonPlad
OK so the transmission in my 94 needs to either be rebuilt or replaced. I have a line on a good t56 out of a gm. I know that it is possible to use the gm t56 but also have read that the viper spec t56 is the best. I have not however been able to get a definitive answer as to why. I know that the gear ratios are slightly more favorable but is it stronger? I will be supercharging the car soon and will need a stronger trany to hold it. Any and all suggestions are welcome.
Ryno8705
There are 03/04 Cobras out there running 550 hp and not having trans problems. If you know how to drive, you should be fine. I can't remember the tq specs for the Viper t56, but IIRC it's not much different than the Cobra's. The primary difference is the gear ratios.
jthorn9
Gear ratios are different, you'll need a T-56 5.0 belhousing, and you'll need to shorten the driveshaft. Might need to cut the welds on the rear cross member and move it back a little as well (not 100% sure on that one though).
LAFENATU
Viper T56 is a lot stronger than the regular T56.
Buy a TKO 500 or a 600.
G
GonPlad
thanks guys...the tko is probably the way I will end up going just going to have to save up a bit. Try and find one used.
