Question for those who have changed rear brakes....
scarface
Not quite sure what the problem is, but I took off my rear brake calipers today to finish installing my 3 inch wheel studs, and when I went to put them back on I didnt compress the piston (didnt have the tool) It was REALLY tight, but it went back on ok....seemed ok.......
WELL, when I went for the test drive my brakes are smoking from that caliper now. ???
Did I screw them up somehow? or do I need to compress them, then reinstall? I cant figure out why it is rubbing?
It was tight as hell going back on, but it did go. The other side went on alot easier.
HELP ME PLEASE.
thanks.
-David
Try and turn that piston in somehow, i used the tool but some say you can do it without.
scarface
I can rent the tool tomorrow Bob, I was just wondering if you thought I needed to or if it sounded like the caliper was frozen up somehow?
Doc_G
Birmingham, AL
some times the tool doesn't work w/out some modification. heres what I did on my 95. With a shop rag over the dust boot use a good set of channel locks to turn the piston in while turning on a c-clamp (to compress it like the front) turn it a few times and add more pressure w/the clamp. you should be good to go after that.
scarface
I understand HOW to collapse the piston... I got the brakes back on without doing it, now one of them seems to be stuck against the rotor. It is smoking and getting REALLY hot.
My question was....Do I have to collapse the piston to may it operate properly, or could it just be coincidence that it seized up now?
That's what I did on mine too.
19mustang95
sounds like the caliper could be locked up, i would try and compress first...but its possible that it seized.
Doc_G
Birmingham, AL
Yeah I dont know who thought putting screw style pistons in the rear was a good idea but I'd like him/her to be tar'd feather'd and ridden out of town on a rail.
OP my apologies for misunderstanding your post.
Pennywise2
Your caliper/s probably failed on you or seized up.
Don't risk your saftey replace the caliper/s.
scarface
Thanks for all of your responses Guys :) there is a pending sale on the car, so I dont want to take any chances. the guy told me he would pay for a new caliper, so I am going to just replace it I think.
chasingomas
