question on my stock headers
96gtchinook
On the headers are the 2 bolts per header part of the header? As in welded in place. Or are they just screwed in?
Thanks in advance.
916_5.0
Do you mean where they connect to the engine or the mid pipe? If you mean the the ones that are connecting the header to the engine they are just screwed in. The two that connect the header to the mid pip i think are just studs.
96gtchinook
I meant to the midpipe, and thanks. If one of those headers threads were junked up i could replace the stud then with stainless bolts?
Nestromo
Worst case drill 'em out, best case you screw it up bad and end up putting some nicer headers on there. ;)
96gtchinook
yeah but I dont want to pull the motor for the headers when the stockers are sufficent. so worst case, I will drill it out and just put stainless bolt with lock washer and stop nut.
