question on o/r h pipe install
GaryG
how hard is it to install an o/r h pipe on a 96 gt, auto? the o/r h pipe is still in the box sitting in the trunk, it sounds pretty good w/ just the mac catback but i wanna slap that o/r h pipe on her, friend of mine is willing to help if it isnt terribly hard
Bluesn95
Waco
Im not sure about an auto install but on a manual, the only hard part is getting the 2 bolts off on the passengers side. When I took mine off for the first time, I stripped my header collector threads. Now that sucked.
Knuckles281
It's easy. Like Gary said, hardest part is getting the passenger side unbolted. Make sure you have extensions, and swivel type sockets; it makes the job much easier
G
GaryG
is there a difference between o/r h pipes for auto or manual? i just went outside to get the part # an its 43960
RJayLo
since our cars are older, Id hit that with PB Blaster too.
My X pipe should be coming in soon so Ill be busy as well :thumb:
G
GaryG
is that the same as WD40? if so, thats what i had in mind
i emailed Mac Performance's tech service, an the part # i listed will work for an auto
Goldmember
Cornwall, NY
PB Blaster is much stronger than WD40. Buy it- I swear by the stuff.
If you can, soak the bolts down once a day for a couple of days before you install the o/r H.
