Question on timing advance
five0joe
Doing a tune up on my 95 GT. Seems like I remember reading on another forum one time, that on these cars, you should not advance the timing due to the computer. Something to do with the way it controls timing, advancing would actually loose power not gain. Any truth to this? I am used to the older A9L, on my 93 I run 17 degrees spout out, no issues with 93 octane, and runs strong. New to the SN's, and just want to know what they like best, stock or advanced. I know other than stock 10 degrees, depends on combo, just want to know if there is any truth to the not advancing due to computer deal. Any help greatly appreciated! Joe
You can absolutely advance the timing, just remove the spout. 17 degrees seems a little crazy, I'd suggest 12-14 tops.
modo
Philadelphia, PA
you realize 17 spout out is less timing then the car would have stock
eec-iv adds 16 degrees on top of the base at wot. car would run better with the base at 14 and the spout in. part throttle would also be stronger as well.
F
five0joe
17 spout out is on my 93, A9L. And spout out is just for setting timing, and not less than stock. As soon as it is set, and you put the spout back in, timing doubles to 34 degrees total advance. Maybe you were thinking I meant locked out at 17?? Either way, no way I would run it at 17 total advance, which would be less than stock, correct, but not the case. Thanks, on letting me know if it is okay to advance on the 95. Not going any where close to 17 on it, mostly stock, that is just where my 93 (not stock) seems to run strongest with no ping/detonation etc. Thanks, Joe
modo
Philadelphia, PA
yeah i read that as you left it at 17 and the spout out
advance the 95 it won't hurt anything. try 14 and if it pings back it down
F
five0joe
No, I do not leave the spout out. I was using that as a reference point. As soon as I put the spout back in, the computer doubles this number. Was just referring to where I set my base on my fox. Guess I should have listed my total, not base, which I do not drive the car that way, only have spout out for setting. Thanks again for the help, Joe
Venom351R
Maine
The total amount you can advance it is different for every car but you will have to run higher fuel as well. 93 if you have it, if not 91 will work
F
five0joe
Yep yep, will do. Just put MSD coil, cap/rotor, and wires on, and replaced plugs. Just filled it up with 93 the other day. Gonna get my timing light out and find out what she likes. Thanks for all the help. Joe
sn95gtvert
Spokane Washington
its all relative to where you live, my 95 loved running with the base at 15 when i lived at 4500 feet above sea level in idaho. now that im back to 500 fasl (Feet above sea level) i have it back down to 13 or 12. and thats with 93 in the tank.
either way, it will help the car a bit.
if i were you i'd start out jumping 2 degrees up each time and if it pings drop it down by one. find the sweet spot and lock it in. but you probly already know all that.
F
five0joe
Cool, will do. I actually had no idea about the dependent on where you are located factor. Makes sense though. Thanks, Joe
sn95gtvert
Spokane Washington
just depends on how thick the air is where you live.
for me in Idaho i was at a high elevation in the high desert.
in Oregon I'm low elevation in a forest near the ocean.
thick air is always > then thin air.
MustangMoser
they will pull timing when there is a lot of base timing, and will pull so much out that you'll be on less timing than with it stock. it's basically a safety net so that morons like us dont blow them up lol. u can get a chip to raise the computer's timing points. i've got the moates quarterhorse for that purpose, its great.
Also keep in mind just because a car isn't pinging with higher timing doesn't mean that a little less timing won't make more power. The most amount of timing is not always the best.
gregbar
When my 95 Cobra was on the dyno timing over 14 degrees actually reduced Horsepower.
Venom351R
Maine
Thats true, when I just had mine tuned recently he added more timing until it stopped making power. Would it take more timing....yes...did it make more power with it...no. My base is set at 10* and my total is 35*
F
five0joe
This is what I was talking about, that I heard with regard to the computer and advance. That was it, that if advanced, the computer will take over, and actually pull more timing out than factory settings. The info I read, said that unless the 94/95 cars should not be advanced unless tuned for it, because the computer would take over and actually pull timing to try and compensate for changes. I have no idea, thats what I was trying to figure out. I agree totally that too much timing on any car can be counter productive. Just wanted to know if even a mild bump, say 12-13 degrees base instead of the 10, would give any performance gain, or if anything other than the factory settings would not improve, but possibly cost power due to the computer. Thanks again for all the help. Joe
gregbar
Yes I wound up going at between 13 and 14 but closer to 13. I will try to find the graphs and might be able to give you a horsepower number.
F
five0joe
Cool, thanks man. That tells me what I need to know. I will play around with it and see what it likes, but keep it 13 or under until I can get my head swap etc. done, and car on dyno to be safe and make sure what its doing. Appreciate it. Joe
