Rear mounted battery
Musturd
Musturd
I did a double take. I now realize you put that in the trunk key spot. I stand corrected! Looks great!!
Thanks man either way you do it some trimming of the sheet metal is needed oh well . By the way ur build is sexy
My only concern is that with the batteries going back there, I am not sure its a good idea to remove one of the two of the ways to gain access to them. I mean if the switch fails by some chance and they need to disconnect the batteries or gain access to the trunk for any reason then you are SOL.
Musturd
Musturd
That is a very valid point you have there Scott. Sometimes I wonder why I smoke so much hmm oh well ill run it like this
You might be able to rig up a wire or something that you can either pull to release the trunk or add a switch there somewhere to actuate the trunk popper. just for safety sake it might be worth it.
Musturd
Musturd
Yea no doubt . I might come up with something . Your supposed to have a fire wall when you have your rear seats deleted or some shit aswell
