Rearend part list
97stanger
Well, after driving my car I'm starting to get a noise coming from the rear, and checked the fluid, was full. Has me believe its a bearing or something. Figured, might as well build the rear while this has come up, considering the build I have now and a bone stock rear wont last long anyway.
The car already has 4.10 gears and a Edelbrock cover
Was thinking about this setup:
http://www.summitracing.com/parts/DTL-913A561/
http://www.americanmuscle.com/moser-31spline-88-axle-9498.html
Keep in mind this is just a street car, so I dont need any crazy setup. However, I am expecting to be in the 550-600 hp range so I do need some beef back there. What ya guys think?
DropTopPony
South Jersey
I had issues with fitment on 2 sets of Moser 31 spl SN95 axels and would probably go with Strange or Superior next time.
The Detroit is a good unit, I use the Auburn Pro and its held up nicely over the last 8 years.
97stanger
97stanger
thanks for the heads up, know where I can check the Strange axles out at?
97stanger
97stanger
I also dont really understand the whole c clip eliminaters either, with a street car should I consider this, or just keep it how it is. Would I need anything else to do the install besides the axles/diff/fluid?
DropTopPony
South Jersey
I have C clips in mine.
Jeggs and Summit probably sell the Superior and Strange axels.
You will need the install kit with all the bearings etc also.
With the fluid I would go Synthetic with the Ford friction modifier also.
I was told I didn't need it and my rear was clunky until I added it, nows its whisper quiet.
97stanger
97stanger
Yeah, I did a bit of research and I think I'm just going to keep mine c-clip as well
19mustang95
if i was building a rear end all over again, i would do the following.
- 03-04 Cobra 31 spline differential (carbon fiber clutches) - only $175ish through Tousely Ford
- Moser or strange 31 spline axles
- 9" ends instead of c-clip eliminators
97stanger
97stanger
he only reason I really like the True Trac is because of not having to worry about clutches burning out
