You do know that the foxbody (drum) axle housing is the same length as the one in your 94-98 right? Unbolt the drum brake backing plates and swap all your disc brake hardware over...
See the four nuts around the axle tube? If you remove those, the drum backing plate will come off.
itll look like this (just not with the axle shaft sill in it.)
Your disc brake backing plate....
Will bolt right on.
Hmm...I didnt think it was that easy to swap them....well I might have a project coming up soon then lol. thank you:grin:
