RedTwilightZERO 1996 Cobra Build
RedTwilight
Roxboro, NC
I guess I'll finally make a thread for the build up of RedTwilight ZERO. My 1996 laser red Cobra.
I purchased it used back in Sept. 1999 with approx. 47,000 miles on the odometer.
This was my first manual car, but I have been driving tractors and four wheelers since I was little. So it didn't take me long to get used to it.
It was completely stock except for the intake air silencer removed and a K&N conical filter.
I drove it this way until Feb. or March when I couldn't stand it any longer. It was too quiet. Something had to be done. So I ordered up a 2 1/2" BBK off road H-pipe and 2 1/2" MAC Flowpath cat back.
The difference and sound was outstanding and just what it needed.
I drove it like this for quite a while. Daily driven, cruising, racing, and even car shows. All the things one would want to do in such a vehicle. I have been through more clutches than I care to count, and even obliterated 3rd in the original T-45. So with that happening came it's first big change.
The almighty and revered T-56 6 speed transmission! I said I could either spend $1000.00 to rebuild the T-45 or put that $1000,00 towards acquiring the 6 speed. And the later is exactly what I did. So after a call to D&D Performance a T-56 with aluminum drive shaft was on the way. At the same time I also upgraded to an 11" clutch.
And this is pretty much the way it has stayed while slowly acquiring parts for paint and body, suspension and other items.
It currently has well over 200,000 miles and several dents from daily driven duties and deer impacts.
It's current list of installed mods are:
Engine and Drivetrain
removed air silencer
K&N cone filter
2 1/2 MAC Flowpath cat back exhaust
Weapon X coil packs
Taylor 10.4mm ignition wires
Custom Ignition wire covers
Tremec T-56 Cobra spec 6 speed
Fidanza aluminum flywheel
11" Centerforce dual friction clutch
Steeda Tri-Ax Shifter
Aluminum drive shaft
'03 Cobra radiator and fans
Exterior and Appearance
Painted body matching calipers
One piece clear projector headlights
Red Cobra grill emblem'03
GMC Envoy fog lights with HID's
Interior
Cheap Cobra Misano L replica seats (true Misano L's to be purchased one day)
'03-'04 Ford Racing leather 6-speed with silver medallion shift knob
Autometer gauge bezel gauge pod
Autometer electric Phantom water temp and oil pressure gauges
Super bright LED's in factory dash cluster
Parts awaiting to be installed: (someday)
'03 IRS (waiting to purchase brake lines / fittings and FTBR bushings and diff cover)
Saleen rear bumper
Saleen side skirts
H.O. Fibertrends 1 1/2" cowl Cobra hood
Shinoda Boss decklid spoiler (still have butI've decided on a different spoiler)
ABC Exlusives Cobra front bumper extension / air dam (still have but unsure if I'll use)
Side Scoops (Stalker style)
Coil on plug conversion kit
'04 Cobra C.O.P's
'04 Cobra C.O.P. valve covers
'94-'98 Export side mirrors
Bullet style pedals
Maximum Motorsports 4 bolt Caster / Camber plates
'04 Cobra front lower control arms
Trunk Springs with Bumpers
Dome light door switch
Door Hinge pins
Front bumper cover hardware
spoiler delete trunk lid
Slowly collecting parts for an Eaton swap!
Griggs Racing GR40 carbon fiber decklid spoiler
Carbon Driven '03-'04 Cobra carbon fiber side skirt splitters
Carbon Driven carbon fiber cowl panel
ThomasW's carbon fiber Firewall panel
Aerocatch carbon fiber hood latches
Rovos Durban Satin Bronze wheels 18x9 front / 18x10.5 rear
Stiffler's "Fit" system subframe connectors, jacking rails, and matrix braces.
Stiffler's tubular transmission crossmember
ZERO
Engine
http://s35.photobucket.com/user/RedTwilight/media/Zero Design/DSC_0784.jpg.html
Calipers painted to match.
Custom plug wire covers
'03 Independent Rear Suspension
'03 Envoy Fog lights and custom brackets
http://s35.photobucket.com/user/RedTwilight/media/Zero Design/427011ae.jpg.html
H.O. Fibertrends 1 1/2" Cobra Cowl hood
Spoiler delete trunk lid
Authentic Saleen Side Skirts
Export mirrors and Bullet style pedals.
'04 Cobra front lower control arms and Parts for eventual Eaton (Kenne Bell / Whipple) swap.
MMR stage III '04 Cobra heads with Manley valves and springs and titanium retainers.
cameron57
Clean car for all those miles. She be a fun car when complete.
Sent from my SAMSUNG-SM-G920A using Tapatalk
RedTwilight
RedTwilight
Roxboro, NC
Thanks! But sadly those are some older pics. It no longer looks as good thanks to a deer or 2 that have put a couple of minor dents in it. Also the paint has faded and is now several shades of red/ pink.
After I get the rear back in my '93 notch I plan to start on the body work and then paint and suspension before Mustang Week next year. Then hopefully after that the engine and engine bay work will begin.
evilcw311
Most Evil Member!
Louisville, KY
Yawn.............is it done yet!?!? Lol
RedTwilight
RedTwilight
Roxboro, NC
Slight update.
Not really any work done, but moving closer to starting.
I got some guide coat, glazing putty, sandpaper, and sanding blocks. I then pulled out the H.O. Fibertrends hood to begin preparation for the endless process of sanding and primer and more sanding all before paint.
Also ordered a few pieces for the eventual restification of the Cobra.
New trunk springs with bumpers
Dome light door switches
Door hinge pins
lutter94
South Dakota
www.latemodelrestoration.com
They also have the whole hinge assembly, but are a bit on the pricey side.
Was afraid of that. See my write up, ask any questions. They didn't want to force their customers to drill out the hinge for new bushings, so these fall in. Problem with them falling in, they're not tight. Curious how yours goes, but the doorman bushings fit great after drilling them out....
www.sn95forums.com/showthread.php?69367-How-To-Replace-Door-Hinge-Pins
RedTwilight
RedTwilight
Roxboro, NC
Thanks for the heads up. I will see how they fit when I get around to it. If not I'll do the Dorman bushings or find some other bushing.
RedTwilight
RedTwilight
Roxboro, NC
I pulled to H.O. Fibertrends Cobra cowl hood out of storage yesterday and started block sanding and prep for primer. The hood is a really nice piece. The only thing I don't like about it is that the scoop bezels were molded in instead of being a 2 piece design like the factory.
So now before I get too far I've got to decide on what to do with the scoops on the hood. Do I want to
1. ~ cut out the moulded in bezels and make mount for the factory scoop bezels?
2. ~ go in with a dremel, files, and sandpaper to sharpen up and deepen the outlines of the moulded in bezels?
3. ~ or fill the outlines and smooth the area around the scoop.
Scoops as pulled out of the box.
Scoops with guide coat on after a little block sanding.
RedTwilight
RedTwilight
Roxboro, NC
Got myself a spare Teksid block. I plan to start building this one for the Eaton / Whipple / Kenne Bell swap while still being able to drive the car. It was a good deal that included the Cobra Engineering timing dowel upgrade kit and ARP main side bolts.
Also I found a spoiler delete trunk lid. So now I don't have to spend all that time to fill the holes for the spoiler in my factory trunk lid.
RedTwilight
RedTwilight
Roxboro, NC
Little update. Not much has been done to the car other than driving it. I've spent most of my time on my '93 coupe doing a full suspension upgrade.
But I have just recently pulled it into the shop and hope to begin doing some work to it soon.
I did make a purchase to add to the Pile-O-Parts.
SVE FR500 steering wheel in black.
RedTwilight
RedTwilight
Roxboro, NC
The SVE FR500 steering arrived the other day and WOW does it feel so much more comfortable than the factory wheel.
TTSaleen
NC
Nice. You need a solid weekend of parts installation and make some good progress! :slowclap:
RedTwilight
RedTwilight
Roxboro, NC
Thanks, but it's going to take a lot longer than just a weekend. I'll probably spend a couple months just on body work. Then all the little bits and details that I want to achieve.
96Mustang4.6GT
