Removing sun visor from 2004 convertible..
yellow tang
Wisconsin
I bought some dye to redo my sun visors. I have a convertible with lighted mirror in visor. I took 3 screws out but visor is not dropping down. looks like a plastic molding somehow has to be unhooked and come down with visor? I'm assuming their is a wiring plug behind that plastic piece to unplug for the lighted mirror? I'm not having any luck finding the convertible video on youtube other than older fox body and mines a 2004
07GtS197
Fort Myers, Fl
It should be similar to a coupe. There is a spring that’s held into place by tension so you’ll need to apply some force to get them out.
Y
yellow tang
Wisconsin
Guess I'm bit confused.. A spring holding visor up in top window surrounding molding.. or spring holding visor onto shaft? I'm trying to remove the assembly to get at wiring plug behind it then bring whole assembly in to re-dye
07GtS197
Fort Myers, Fl
There is a spring holding the visor onto the ceiling.
Mikehonco69
