Replacing a throw out bearing got expensive!
justinschmidt1
I pulled my tranmission to replace the clutch.
Then I replaced every single part on the entire car, mini-tubbed it, built a new motor, got a new transmission, changed out the entire interior, added 200 pounds of sound deadener, and spent $20K.
Paul.
Thats cause your the man.
ivan12
Happened to me too just not to Paul's extent. Pulled motor to put in a fresh bottom end and the car ended on jackstands for almost 2 years. New motor, H/C/I, blower and tubular suspension
A
AlbinoGorilla
Pensacola, Florida, United States
lil update, got my tubular k in today, and got her set up to swap them out tomorrow. Wish me luck! OH and a picture of the old pilot bearing. No wonder it was making funny noises.
ivan12
I hate the damn pilot bearings, I have a picture of mine in my build thread. Had to come out in pieces
ivan12
I smacked mine so many times with the slide hammer that the inner bussing popped out by itself. Then I had to take a mallet and chisel to the outer ring to break it apart. Luckily the engine was on a stand at the time
A
AlbinoGorilla
Update: Got the K member installed and everything. I had 0 fitment issues! Thank God! All that was required is cutting off the rounded areas on the control arms. The only complaint i have was the hardware they supplied for the steering rack. The bolt sheered off while i was taking it out to install my rack. So, i had to drill it out and re-tap it. Other than that I recommend it. Oh and K-member bolts are hookers! That is all.
