*replacing igniton key cylinder*
purplehaze
i am trying to replace my ignition key cylinder. has anyone done this before or can tell me where i can get this done? want to replace it due to it getting jammed/locked and being able to turn car on without key!
lutter94
South Dakota
Not sure on stangs, but i literally just got back from replacing it on my 92 F150. There is a pin hole on the bottom side, stick something narrow up in there, then turn the key on and you should feel it move in...after it is in the cyl should slide right out. That's the way it is on my F150, and my stang is 150 miles away, so i can't go look. You may have to take off the trim around the steering column...but it should be pretty straight forward.....good luck
tommybunz
disconnect battery turn ign. to on position, there is a little hole in the black plastic that surrounds the wheel. you must use a skinny ice pick or screw driver push the pin in and pull the lock out. the new one should already be in position so just slide the new one right in.
P
purplehaze
thats all i need to do? i dont have to remove the cover around the steering wheel or connect any wires? im going to go buy the ignition cylinder later today.thanks
95 svt cobra
There is a pin hole underneath the tumbler on the underside of the steering column, you should be able to take an awl or something of that matter and push up in it and your tumbler should be removable. Ford wants i think 45 bucks but you get 2 ford keys with it.
Mustanger
Southern Oregon
Will that fix the looseness in the ignition that causes the beeper to sound off when you open the door even when the key is not left in? Or do you have to replace more parts?
mdnitedrftr
Keep your receipt. You might not need a new one. I have the same problem on my car, and from what Im reading, alot of people just have to clean it, and spray it with some silicone to unstick the pins.
Im hoping thats all mine is. Ive got enough money to spend on this car, lol.
P
purplehaze
got it done! followed everyones directions and it was straight forward! turns on/off easily! thanks everyone!
tommybunz
ok here we go for that beeping just disconnect the harness thats what i did no problems. look on the side of the trans tunnel driver side soon as you look there should be a long whitish yellowish connector keep your door open so you know and unplug it if the beep stops your all set. just remember to keep the key in the ign.
Mustanger
Southern Oregon
LOL..Thanks that is good to know...but I NEED the beeper, I'm kinda old & forgetful nowdays..why I even locked my keys in a convertible & the top was down!
topless95
too funny
