ReplicaR's Time Trial Mustang build *Engine Rebuild*
its all about the enclosure. a bad speaker placed in the properly designed enclosure will make more bass.
evilcw311
Most Evil Member!
Louisville, KY
Enclosures always make a difference. That’s why the 460 sounded so good with so little as Scott said.
R
ReplicaR
Ok, dropped the car off at the stereo shop again, getting the floor board covered in dynamat, and 10 inch sub installed in the rear shelf, between two speakers. I've specifically asked for the car to be rattle free, so let's see what happens.
evilcw311
Most Evil Member!
Louisville, KY
Are you having them build some sort or enclosure under the deck for the sub or are you trying free air?? If trying free air hopefully the sub is one that’s recommended for free air.
Be warned though, free air doesn’t always work as people think. You still have to have something to restrict air flow behind the sub or it will not work as intended.
They use to make a cloth specifically for free air subs that you’d use to make a wall directly behind it. This material if used correctly restricted the airflow like a box would but it didn’t take up space.
R
ReplicaR
I got a call saying that the car is ready, so I guess I'll find out tomorrow.
R
ReplicaR
Checked out the car in person today, major difference from before. There's a very good amount of bass, although it's a fairly soft hit, not as sharp as in my Infiniti for example. Overall pretty stoked with it. I think a change of mufflers will help with a quieter cabin, because what's on the car now (10 year old bassani) is letting in a LOT of droning . I'm thinking Spintech 3000, which shouldn't impact performance much, but should get rid of that 2000 rpm drone of death
R
ReplicaR
I decided to wrap my interior in tinfoil so that aliens can't read my mind... Lol, just kidding. The floor board has been covered in Dynamat to reduce temps inside of the car, as well as sound and vibration reduction, all in efforts to make the car more steerable and enjoyable in other environments aside from race track.
evilcw311
Most Evil Member!
Louisville, KY
I don’t see dynamat written all over it so I’m calling bs!! I think your really worried about the government or aliens tried to scan your brain............. [emoji1787]
R
ReplicaR
You are correct, that's not a Dynamat brand sound deadening liner, some other brand. Funny how certain manufacturers are at the forefront of the certain segment to the point where we refer to all product by that name? Kinda how most people would say take a Xerox instead of take a photocopy, etc.
Also, Roswell was covered up, earth is flat, vaccines cause autism, [ insert other conspiracy theory nonsense here ]
OLD H2S
Silver Spring Maryland
I have a spare set of BBK Vari-tune adjustable I liked a lot, work well on the drone because you could adjust each one so they will not over lap and adjust for total Db. And I have a set of Ford FRPP Bulitt mufflers I am not using that are really good sounding. At idle its got that Steve McQueen rumble and perfect when you hit the RPM, but they were 750.00 a pair, yours for 400.00
I do a lot of custom TIG welding so I make up different exhaust systems and run them for 6 months and make something new..
I have a set of Edelbrock ceramics around some where??? and a set of the sound canceling bullets that work well but are loud at idle but get quite when you push them hard.
R
ReplicaR
Thanks for the suggestions, but I'm pretty much set for the exhaust work. I am putting high flow cats on the car to clean up the gasoline smell, because after driving it for longer than 5 minutes, I smell as if I was swimming in it. I talked to Magnaflow, and they said that the highest flowing catalytic converter they have is one with 200 cell count, so that's the cat I went with. Another thing I'm doing is replacing 10 year old Bassani mufflers with a Spintech Sportsman 3000. They say that it's the quietest performance muffler they have, and it's supposed to reduce a lot of drone, so that's what I'm counting on between cats and the new mufflers.
My exhaust system has become a complete Frankenstein. BBK Short Tube Headers into Bassani downpipe into Magnaflow 18 inch resonators into Magnaflow high flow cats into Bassani X pipe into Bassani catback exhaust pipe into Spintech Sportsman 3000 muffler into Bassani tip. I should have some fun with it and replace the Bassani tip with a Borla tip, just to cover ALL brands.
R
ReplicaR
Here is some of the Frankenexhaust so far, that hasn't been installed yet. SpinTech Sportsman 3000 mufflers #BaffledAF
evilcw311
Most Evil Member!
Louisville, KY
So you customized a muffler?!?! That’s hardcore shit right there!!!
evilcw311
Most Evil Member!
Louisville, KY
Nah, that's how they are off the shelf.
Well just piss on the parade while don’t ya!!! Lol
I thought by frankenexaust you had cut em up and changed stuff.
That’s what I get for not reading up far enough I guess. [emoji38]
I thought by frankenexaust you had cut me up and changed stuff.
This is what happens when your pooping and reading, other then getting confused which hand to wipe with.
R
ReplicaR
Also, these are going in too finally. I only commissioned these a year ago, and picked them like two weeks back, @B.mad had to keep them on the self for almost a full year lol.
Tillerman77
Southern MN
Sweet! Were the cores Eagle Eyes?
Please show them when you get them on the car along with lighting impressions on the road.
R
ReplicaR
Yes, Eagle eyes housing, had them in the past, really liked them. I'll take some nighttime pictures
