Nope, my car is just all around bad assness. I’ve done a bunch of drag racing with this irs and never had a problem with it.So the car has a built automatic which is typically more for drag but your running an irs which is typically more for cornering.
Am I missing something or does your car have an identity complex!?!?! [emoji38]
You ain’t lyin! Those level 5 axles cost more than I’ve got in my engine.I’ve seen guys drag them a bunch before. Main problem is generally tire hop which is due to the factory rubber bushings. The guys who used Delrin and upgraded everything I’ve seen launch hard on slicks on some pretty serious power. After that it’s the axles that’s are the weak link but only seems to be an issue for the guys around 1k power. The aftermarket axles are FAWKIN expensive!!!!!!!
Wow! That's alot of work to do and not find out what it is. What type of vibration, where can you feel it the most t in the car?We swapped that rear end trying to find a vibration that I’ve got. Did all that, to no avail.
The vibration is everywhere in the car and it starts around 40ish mph and gets worse the faster you go. It’s violent at 140 mph. It feels like driveshaft angle but up and down angle is good. I need to check and make sure the k member is square to the rear end to check the left-right driveshaft angle.Wow! That's alot of work to do and not find out what it is. What type of vibration, where can you feel it the most t in the car?
What you said about all the angles is to the T exactly what 870% for get to do. I know you will definitely get it figured out.The vibration is everywhere in the car and it starts around 40ish mph and gets worse the faster you go. It’s violent at 140 mph. It feels like driveshaft angle but up and down angle is good. I need to check and make sure the k member is square to the rear end to check the left-right driveshaft angle.
Yeah, I didn’t even think about side to side alignment. @OLD H2S is the one that suggested I check that.What you said about all the angles is to the T exactly what 870% for get to do. I know you will definitely get it figured out.
I understand, I'm pretty harsh on myself also. When you have alot going on, especially with what your doing, it can be simple to over look something. Ive got mine tore apart also. I sit and think about things I want to do, and how, then write it down. When you spend years collecting parts, it takes a little to get everything just right.Yeah, I didn’t even think about side to side alignment. @OLD H2S is the one that suggested I check that.
Which is really dumb on my part. Coming from a transmission shop, I used to check driveline alignment all the time.
It won’t take you long to get it right. Your attention to detail won’t let you mess up.I understand, I'm pretty harsh on myself also. When you have alot going on, especially with what your doing, it can be simple to over look something. Ive got mine tore apart also. I sit and think about things I want to do, and how, then write it down. When you spend years collecting parts, it takes a little to get everything just right.
Thank you good sir.It won’t take you long to get it right. Your attention to detail won’t let you mess up.
