wayne94mustang said:studs are stronger and easier to ajust IMO
topless95 said:wayne94mustang said:studs are stronger and easier to ajust IMO
x2
Paul said:topless95 said:wayne94mustang said:studs are stronger and easier to ajust IMO
x2
x3
Also, it's not a Ford or Chevy thing. It's just stud mount or pedestal mount.
lol!!!!!!!!!!!!!!!!Paul said:Do you mean shaft mount?
LAFENATU said:Energizers are Pedestal arn't they??
Either way unless your making 500+ hp, pedestal will be fine but, they are correct..Stud mount is definitley stronger.
wayne94mustang said:HP has nothing at all to due with pedestal rockers being weak...its the HD valve springs
and i think 5/16 pedestal bolts are only good to about 350# springs
LAFENATU said:wayne94mustang said:HP has nothing at all to due with pedestal rockers being weak...its the HD valve springs
I have heavy duty .600 lift springs with Cobra 1.7's - no issue here. I contacted crane before hand to make sure I wouldn't run into a problem with a broken rocker. The tech at Crane told me unless I am running over 500HP I shouldn't have an issue.
Hopefully I am going to be alright..
topless95 said:LAFENATU said:wayne94mustang said:HP has nothing at all to due with pedestal rockers being weak...its the HD valve springs
Actually you will run into a problem at 499 1/4HP (LOL)
